Author Topic: Flow 8 Mixer - no sound  (Read 1449 times)
David Rix
« on: February 01, 2023, 10:43:23 PM »
Hi,
The Flow 8 mixer all okay 2 days ago, but when plugged in today, no sound coming out.
Bluetooth is connected okay as are Mics and Line in from PC.
All lights seems to be working however the VU meter is dead, and nothing through headphones.
What could be the problem?
What haven't I done or done ?
Thanks
Tracy Garner
Re: Flow 8 Mixer - no sound
« Reply #1 on: February 02, 2023, 09:12:33 AM »
I would go over to the Behringer blogs on their site for more guidance.
Some quick things to check though
- Go into routing on the app and check to see if BT/USB play is set to main mix or phones.
- Check the From PC USB1/2 or USB 3/4 is selected to go to a channel or MON OUT 1/2.
- Check the PC and make sure the PC shows the Behringer as a soundcard. Maybe something changed on the PC changed the USB output.
Weogo Reed
  • Western NC,
    • LiveEdge
« Reply #2 on: February 02, 2023, 10:08:24 AM »
Hi David,
Try:
Disconnect the mixer from the computer.
Do a hardware reset:
 https://www.sweetwater.com/sweetcare/articles/behringer-flow-8-factory-reset/
Connect phone/tablet/whatever control device with Bluetooth, make sure mixer's Bluetooth Active light is on.
One mic in Channel 1 to main mix, can you hear it in headphones?
Connect to computer and as Tracy noted, make sure it is showing up properly in DAW.
Thanks and good health,  Weogo
David Rix
« Reply #3 on: February 02, 2023, 05:32:48 PM »
Many thanks guys, will try them all.
Appreciate your help.
Page created in 0.038 seconds with 24 queries.
