Author Topic: Laptop into mixer is buzzing  (Read 1164 times)
David Aberdeen
« on: November 07, 2022, 06:44:03 PM »
In our church sound system, we use a Macbook for the presentations, which sometimes include video/audio clips.  About half an hour into the service, this channel develops a buzzing noise.  I'm trying to work out where this noise may be coming from, and how to prevent it.
The laptop is connected through the headphone port (3.5mm stereo) , through to 2xRCA plugs at the mixing desk input.  The headphone to RCA cable is about 3m long, and not shielded.  It is run along a cable tray with lots of other cables, including power.  When first setup, it is fine, with no noise, but at some random point during the service, it develops a constant buzzing noise (not 50Hz), and requires that we turn off the laptop sound channel when it's not needed.  The laptop is not connected to power, and just runs off battery.  At the mixing desk, we have options for XLR inputs.
Is it possible to get (or build) a passive shielded cable to take the 3.5mm headphone jack through to XLR inputs?
Is this likely to help?
Is there a better way?  I know we could take the headphone signal through a stereo DI box and convert to balanced, but I'd like to avoid that extra cost/complexity if all it needs is a cable.
Dave Pluke
    • BIGG GRIN Productions
Re: Laptop into mixer is buzzing
« Reply #1 on: November 07, 2022, 07:29:07 PM »
Probably. First, Check the Rules, Change your ID to your real name.  Then, we might be able to offer some suggestions.
Dave
Tracy Garner
« Reply #2 on: November 08, 2022, 09:03:48 AM »
On the 3.5mm does it have 1 or 2 black rings? You can usually do it without going to a balanced DI Box but in a church, I would rather go the DI route - even passive. If you search around the forums here, you will see several recent threads with suggestions for boxes from $20 to a couple hundred depending on what you are trying to accomplish.
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
« Reply #3 on: November 08, 2022, 09:57:48 AM »
Purchase a Peavey USB-P USB Playback Device and be done with the whole ordeal.
Everything else is a compromise.
  • Old enough to know better
  • Audio Plumber
« Reply #4 on: November 08, 2022, 10:50:15 AM »
^^^^^THIS^^^^^
Mike Caldwell
  • Covington, Ohio
« Reply #5 on: November 08, 2022, 12:17:56 PM »
It's not the cable itself but needing isolation between the the computer / video system and the sound system.
The DI would work chances are you'll need to flip the ground switch.
The mentioned USB-P works great, plug it into your computer and then set up the audio out to use it as the default audio output device.
Jonathan Johnson
« Reply #6 on: November 08, 2022, 03:00:20 PM »
I can't address Macs specifically, but I've noticed this behavior with other PCs when they go into sleep mode. The sound card is somehow put into a different mode that puts noise onto the line.
You might need to disable sleep mode during the service.
Or get a dedicated USB audio interface, such as the aforementioned Peavey USB-P, and avoid noisy onboard audio devices and unbalanced lines altogether.
David Aberdeen
« Reply #7 on: November 08, 2022, 05:59:23 PM »
Thanks for the responses.  I will look into these possible solutions.
Ole Anderson
« Reply #8 on: November 09, 2022, 08:42:13 AM »
Unplug your wall wart and try running it on battery alone.  That is often your source of buzzing. Edit: I see you are already running on battery.
« Last Edit: November 09, 2022, 08:44:45 AM by Ole Anderson »
Stephen Beatty
« Reply #9 on: November 09, 2022, 09:42:37 AM »
This is the best thing to do as suggested above. The Peavey USB-P USB Playback Device is a plug and play device. It has 2 XLR balanced outputs and can be run in mono or stereo mode. I have used it on Windows, Mac and Linux driven machines. So who ever brings in a laptop to play can hook up easy.
You will start to see USB-C only machine so get the appropriate USB cables.
Page created in 0.071 seconds with 23 queries.
