Author Topic: Power Amp Losing volume?  (Read 2712 times)
Thomas Le
« on: September 17, 2022, 04:38:42 PM »
Story time:
Got an amp rack that has 4 QSC CX that are 22 years old. Just got a notification from one of the pastors on friday that the "volume was not as loud as it used to be". My thinking was that one of the main amps finally gave up and bit the magic dust. Upon inspection, all 4 are turning on still working, but after some testing and going back and forth from the amp rack room, I'm guessing one of the channels is giving a lower output even though nothing has changed in DSP land and the attenuators are at full tilt. Fortunately the way the system was spec'd,  the installer only used one amp, one channel per side, so there's two amps for FOH speakers, and I was able to switch to channel 2 on the amp. Obviously given the age, I am "working my way up the chain" on trying to get them replaced with CDi Drivecore equivalents.
The stupid question: based on this experience, can a power amplifier lose it's output/volume over time?
Re: Power Amp Losing volume?
« Reply #1 on: September 17, 2022, 04:58:10 PM »
Story time:
Generally no with modern solid state amps and 22 YO is modern solid state...   Are they getting unusually hot? Are speaker loads in good shape?
Thomas Le
« Reply #2 on: September 17, 2022, 05:07:53 PM »
I'll admit the amp room temperature varies wildly because it does not have good Air Conditioning flow but it does not get hot. Speakers themselves are ok once I switched over to the other channel, nothing has changed on the speaker side, all original drivers, nothing blown.
« Reply #3 on: September 17, 2022, 05:15:55 PM »
The amps could be tired... Loose power transistor screws could overheat leading to a soft shut down. Air flow blocked by 22 years of dust could compromise cooling.
Shorted speaker wires could cause problems, but generally failure is not graceful, more severe.
I am not familiar with innards of the CX but some amps have clip limiting that would fold back amp level/gain in case of current limiting or thermal overload.
Bob Taylor
« Reply #4 on: September 17, 2022, 05:27:58 PM »
If the Amp is down just a bit, like 6 dB, are all the inputs on the Balanced interface making connections on both Pos and Neg? And this means at the processor also. Wiggle stuff, re insert, even open up the amp and Re Seat Ribbon connectors? Flip the input/mono switches a few times to break the 22 years of corrosion.
Not played with this amp, but at first read i say it is a corroded jack or........
Bob T
Ike Zimbel
    • Zimbel Audio Productions
« Reply #5 on: September 17, 2022, 06:13:17 PM »
Story time:
I know that the earlier QSC's can. One of the features of the QSC design was split level power supply rails. I don't remember the exact voltages, but say +/-35v and +/- 70v.
The idea was that for lower levels the amps would run on the lower voltage rails, switching over to the higher voltage rails on peaks, louder passages etc. When I managed a soundco back in the 90's we had probably around 300+ QSC amps, 3500's, Mx-1500/1500a, EX2500, EX4000 in heavily used inventory. Almost the only failure we ever encountered, and that very rarely, was the circuitry that would switch between the two sets of power supply rails would stop working. So, it IS possible for an amp of that design to only run on the lower supply rails, and that would be on only one channel because that circuitry was on a per channel basis. And, the symptom was the amp worked fine, but wouldn't produce full volume. I can't swear to this, but I believe it was a FET transistor that did the switching, and is what would fail.
~Ike Zimbel~
Wireless frequency coordination specialist and educator.
Radio Active Designs
Pro Audio equipment repair and upgrades.
~416-720-0887~
Thomas Le
« Reply #6 on: September 17, 2022, 06:17:37 PM »
Bob T
yeah I checked the phoenix connections, all snug. When I changed the amp channel, the perceived loudness of the system was "back to normal", so the input cable is ok.
Steve-White
  • Fort Worth
« Reply #7 on: September 17, 2022, 06:51:07 PM »
Any and all connections could be suspect.  Even inside the amps.  Sometimes just a simple remove and re-seat can cause problems to disappear.  This applies to both XLR connectors and connections within the amps.  Heat and cool cycles in the amps can cause issues after years of use.
I would wonder if the line feeds are contiguous from the FOH to the amps?  i.e. no connectors along the path?
Paul G. OBrien
« Reply #8 on: September 18, 2022, 05:53:25 PM »
Simply disconnecting and reconnecting the wire may have "fixed" the problem (if it is corrosion), a test for this would be to now reconnect the wire to the original channel.. if the signal level is back to where it should be then you have confirmation.
« Reply #9 on: September 19, 2022, 11:20:19 AM »
If the upper rail of class g/h amp is not working the gain will be the same, but it will clip sooner. This may be audible in full tilt use, but not obvious for normal listening levels.
Bob T
+1 missing one leg of differential source could look like -6dB loss.
Page created in 0.056 seconds with 23 queries.
