Author Topic: Thinking outside of the box for commercial amps due to supply issues  (Read 1419 times)
Ben Carson_
  • Ben Carson
Provided a QSC quote involving MP-A80 8 channel amp for a sports bar and it was approved.
They were in stock when quoted but now ETA is several months out, and this is the same with other preferred options like the QSC CX404, Crest CM2204.
I am just powering a bunch of JBL Control speakers @ 8ohm
Security faceplate / or no front controls is a neccesary feature
New Class D would be welcomed, as heat and fan noise are an issue; gear is stationed just 5' from patron seating
While looking for alternatives I came across an alternative: ART SLA4.
These guys are meant for the studio, but they recently released at 70V version, which implies that the SLA4 predecessor might be suitable for installed sound too. After all, studios run gear 18 hours a day much like public venues.
4 x 100 Watts/Ch @ 8 Ohms, 140 Watts/Ch @ 4 Ohms
2 x 100 Watts/Ch @ 8 Ohms & 1 x 280 Watts @ 8 Ohms (bridged)
They are inexpensive ! Just $500 Canadian.
Too good to be true?
Anyone have experience with these or doing something similar?
Dave Garoutte
  • San Rafael, CA
Re: Thinking outside of the box for commercial amps due to supply issues
« Reply #1 on: June 22, 2022, 07:36:48 PM »
Please change your display name to your actual name per the forum rules.  No one will reply until then.
Ben Carson_
  • Ben Carson
« Reply #2 on: June 26, 2022, 06:08:53 PM »
Looks like this forum post here covers this exact discussion pretty well:
https://forums.prosoundweb.com/index.php/topic,176677.0.html
If the CX series were available I don't think it would even be a question. These things are rock solid.
Mike Caldwell
  • Covington, Ohio
« Reply #3 on: June 26, 2022, 11:03:56 PM »
For what it's worth I've put a couple ART SLA-2 amps in installs and they are working fine for their application.
One is driving 8 ohm loads and the other is in bridged mono driving a 70volt system with 8 JBL ceiling speakers.
Brian Jojade
« Reply #4 on: June 27, 2022, 12:29:47 AM »
I've worked with quite a bit of ART stuff over the years.  Never had any reliability issues, although many times it was on the noisier side of things.  For many cases, that doesn't make much difference. At the price, it could be a stop gap install until the real stuff gets in too.
Brian Jojade
Ben Carson_
  • Ben Carson
« Reply #5 on: June 27, 2022, 11:56:25 AM »
Thanks for the feedback Mike and Brian. Last night I convinced myself to go the Crown XLS route, and bridging 2-4 8 ohm speakers per channel. But for the price of the ART SL4 could install a couple and have each speaker on its own output. I thought I may have gone off the deep end with considering Art for the application, but hearing that reliability issues are not a problem has me reconsidering.
By "noiser" are you referring to fan noise or signal to noise, or both?
Brian Jojade
« Reply #6 on: June 27, 2022, 12:31:28 PM »
The signal noise is what I was referring to.  Just a little more hiss than I like (which is none, of course!) but not bad enough to be a deal breaker.
Brian Jojade
« Reply #7 on: June 27, 2022, 02:06:55 PM »
Most amplifiers use common innards, even more so now with class D amplifier chip sets. Different SKUs for different markets will mainly differ in feature sets.
Mike Caldwell
  • Covington, Ohio
« Reply #8 on: June 27, 2022, 07:09:10 PM »
What do you mean by "bridging 2-4 8 ohm speakers per channel" ?
The XLS series has the advantage of the the basic on board DSP most importantly the high pass filter option.
Tim Hite
    • Bad Quail
« Reply #9 on: June 27, 2022, 11:58:41 PM »
Dynacord and Linda Research are both currently delivering quality power amplifiers.
Bad Quail
Sound + Light
Joshua Tree, California
Authorized Dealer for all this stuff
Page created in 0.036 seconds with 23 queries.
