Author Topic: Audio to Video sync problem  (Read 2404 times)
Cass Johnson
« on: June 10, 2022, 02:01:35 PM »
We recently recorded a Live Studio Talk Show (which can't be re-filmed) although we had basic "In Camera" audio and it wasn't that good. Our sound tech recorded the show through two wireless lavaliers into PreSonus "Studio One" on a laptop. When the tracks were provided to me they are 1:55 (one minute-fifty five seconds) longer than the video and in camera audio. HUGE problem - the audio is crystal clear but I have no idea if there is anything I can do in order to reduce the overall timing to fit the video. I really hope someone can direct me to a fix or the entire show is a wash.
Dave Garoutte
  • San Rafael, CA
Re: Audio to Video sync problem
« Reply #1 on: June 10, 2022, 02:29:35 PM »
You need to go into an NLE (like Resolve)and do a little editing.  Align the audio, then clip off the extra.  Or if they are actually in a different time scale, you can stretch or shrink the video or audio track to fit.
Corey Scogin
  • Birmingham, AL, US
« Reply #2 on: June 10, 2022, 02:34:29 PM »
As Dave mentioned, if it's an actual clock drift issue, many modern DAWs will allow you to time stretch audio. I do not know if Studio One does. All allow you to trim/shift to adjust timing.
In Reaper, you can import the video along with every audio track and either stretch (shrink) the audio tracks as a whole or add "stretch markers" at intervals to the out-of-sync audio then manually align it with the audio/video track.
Most video editors have multi-track sync capability but I'm unsure if any stretch automatically. I think most just shift to align.
Reaper, Resolve, Premiere, Final Cut Pro, maybe even iMovie can be used to fix your issue.
« Last Edit: June 10, 2022, 02:36:34 PM by Corey Scogin »
« Reply #3 on: June 10, 2022, 04:03:13 PM »
Could be the difference in frame rates, 30 fps vs 29.97...
"Art has always held a tenuous position between acts of subversion and status symbol collected by those who profit from the very status quo the art purports to subvert." - Stephen Colbert
Mike Caldwell
  • Covington, Ohio
« Reply #4 on: June 10, 2022, 05:56:22 PM »
How long is the total video?
If there are any cut away/b roll shots getting cut into the finished video those are good places
to slip the audio track to adjust the sync.
Bill Meeks
« Reply #5 on: June 10, 2022, 10:04:47 PM »
Sounds like to me the sound operator just either started recording earlier than the camera guy, or he stopped recording later than the camera guy. Or perhaps a little of both and that equals the 1 minute and 55-second differential in length between the two tracks. What I understand from the OP is one audio track came from an internal mic on the camera or else an external mic plugged into the camera, and a second track came from two wireless mics directly into basically a DAW. So the "in-camera" audio is already embedded in the video, but then there exists a separate audio track that was from other mics straight to basically a DAW. In that situation I would expect the length of the two tracks to almost never be the same. It would take a small miracle if both recordings started and stopped at the identical same instant.
Compare the lead-in portions of both audio tracks (recorded and in-camera) and see if there is some period of dead time in the recorded track. I'm betting there is. So in a DAW import both tracks and find a convenient "first good sound" point and line the tracks up by shifting the recorded track left or right as necessary. Once you get them properly aligned, you can trim the recorded track to match the length of the in-camera audio track.
« Last Edit: June 10, 2022, 10:07:47 PM by Bill Meeks »
Dave Garoutte
  • San Rafael, CA
« Reply #6 on: June 10, 2022, 10:33:29 PM »
Like I said.  Resolve (it's free) has a one button audio align tool that is amazing.
Patrick Tracy
    • Boulder Sound Guy
« Reply #7 on: June 11, 2022, 12:19:28 AM »
I use Vegas Pro 18 for video editing and audio recording/mixing. It would be a fairly trivial matter to "resize" the audio to fit the video. It's essentially a resampling process. I would drag the beginning and end of the audio to clear landmarks that I can reference to the camera audio, line the first one up then stretch/squeeze (CTRL-drag to engage Time Stretch) the audio clip so the end landmarks lined up. Then I'd drag the beginning and end back out if needed. This is where having an audio slate at the beginning and end of the take is helpful.
Most likely there was a discrepancy between the clocks. For example, the clock on the Zoom H4 and H4n (non Pro models) is notorious for drifting when set to 44.1 kHz, but usually synced up well with other digital devices at 48 kHz.
Jordan Wolf
« Reply #8 on: June 12, 2022, 08:19:55 PM »
This is an issue when one file is recorded as VBR (variable bitrate) and the other is record as CBR (constant bitrate).
I ran sound for a wedding and recorded the audio from the console on my Tascam DR-40, which records in CBR. My mother-in-law captured the event on her iPhone, which recorded in VBR.
The files end up tracking differently and I have to match them up in post- using time stretching/shrinking.
Jordan Wolf
Corey Scogin
« Reply #9 on: June 12, 2022, 10:14:16 PM »
VBR and CBR encodings using the same type of codec (mp3, aac) should align perfectly if the hardware clocks are in sync. If they do not, something is broken in the encoder or decoder. CBR is just easier for software to determine position and length due to the fixed number of bytes per time period. Some codecs add samples to the beginning of the file, shifting the audio slightly but that shift should be consistent for files encoded with the same codec type.
Page created in 0.075 seconds with 24 queries.
