Author Topic: Small PA + Stream For Synagogue Chapel  (Read 1197 times)
Herman Wolf
« on: March 31, 2022, 12:45:28 PM »
Hey, fam.
Part-time listener, first-time caller.
I've been taking audio gigs at a local synagogue for the past year.
Last week they asked if I could help them put together a small PA / streaming solution for their chapel.
They paid through the nose for a ridiculously OP system (Digico/QSC/Bose) in the main sanctuary and have no intention of repeating that experience so they called me instead of their AV contractor.
I'm here to ask for help with gear selection.
The chapel is oblong in shape, ~50'L x ~25'W x ~20'H. Speakers will be mounted on the walls flanking the podium. Photos forthcoming.
They already have dedicated streaming hardware (Podium Mic > Panasonic UX series 4K camera > USB HDMI capture > ThinkPad (Intel Graphics)).
They want to add a small PA.
I'm envisioning something like this:
There are several points to consider when specifying equipment for this project.
1. Budget. They don't want to spend more than ~CAD$3000 on the new purchases.
2. Expertise. The individuals running the stream and PA are utter normies, untrained in audio. The system must be dead simple to operate; basically set-and-forget like the one in the main sanctuary.
3. Layout. We need to make the equipment as unobtrusive as possible. Hiding cables is not impossible but it will be a challenge given the nature of the room.
A dedicated DSP is probably overkill in this room, and they need some kind of level control for the PA, so I figured a small digital mixer would fit the bill. The Behringer Flow 8 has all the IO they need as well as corrective EQ on the outputs. For the record I'm not a fan of Behringer but I can't think of another mixer that is as small with as many features for even close to the same price.
I'm envisioning a pair of passive wall-mounted array-style column speakers.
Passive because one of the speaker positions doesn't have power nearby, whereas speaker wire can be dropped down the wall cavity from above without too much trouble (I think).
I don't know the installation market very well at all.
Is there a mixer (besides the Flow 8) or a DSP/control surface solution that is a) inexpensive and b)can be configured for simple operation?
What are some speaker / DSP / amp brands I ought to consider? The amp needs to be as small as possible.
Thanks for reading!
« Last Edit: April 02, 2022, 04:33:41 PM by Herman Wolf »
Dave Pluke
    • BIGG GRIN Productions
Re: Small PA + Stream For Synagogue Chapel
« Reply #1 on: April 01, 2022, 03:35:44 PM »
Am I correct in assuming the program material is primarily Spoken Word plus a Cantor?  If so, you may find the JBL CBT series of column speakers will fit the bill.
I installed a pair of CBT 100's in a Synagogue a couple of years ago and found them well behaved and needing no real EQ in that role. I mounted them up high, aimed down and the output was very even across the room. They were powered by a Crown XLS 2002 driven by a Soundcraft Ui24R "console".
I bought a Flow 8 to carry as a backup and for Break-out sessions. The bluetooth control app is a bit clumsy but, once set up, the simple up/down Faders should keep most users out of trouble.
Sounds like you're on the right track.
Dave
Herman Wolf
« Reply #2 on: April 01, 2022, 07:37:09 PM »
You are, indeed. Speaking and Canting; but only one at a time, and from the same position, so we can get away with a single gooseneck mic.
(That said, if we're going to be running cables through walls and floors I will definitely wire up more than just one!)
I'll check them out as soon as I finish this reply.
I'm a little more limited with regard to placement. I'm pretty sure they'll be firing over the heads of the folks in the first two rows.
Yeah, given its price, size, breadth of control option and simple fader layout it seems like the best option for this scenario. I'll hold my nose and add it to the project scope.
Dave
Thanks, dood. 👍
Herman Wolf
« Reply #3 on: April 02, 2022, 12:20:41 AM »
I'm considering running Cat6a (I have a spool left unused from a home renovation) instead of multipair audio snake from the podium to the back of the room.
The particular cable I have is pretty inflexible and hard to pull but it's 23AWG and every pair is individually foiled. It has an overall braided shield IIR.
It's also cost me only only about ten cents per foot which is like fifteen times less expensive than 4-pair Canare (which I just priced at CAD ~$6.50/meter).
I've never used Category cable for analog audio before but Dave Rat seems to think it works a treat.
I've been trawling other threads trying glean opinions on using Category cable for analog runs but have yet to arrive at a consensus.
Thoughts?
Mike Caldwell
  • Covington, Ohio
« Reply #4 on: April 02, 2022, 12:40:37 AM »
Maybe for the PA processor/mixer look at something like a DBX Zone Pro. That would do everything you need and once properly set up you could have one remote volume knob.
Simple software, easy to program.
« Reply #5 on: April 02, 2022, 05:19:34 AM »
Hey, fam.
Thanks for reading!
The streaming is important.  There is free software called Open Broadcast Studio, OBS.  If you have basic computer skills it has very nice features including a titler and the ability to "wipe" between the video and slides.  The real benefit is that is connects directly to services like Youtube and Facebook and bypasses all their processing.  Your audio stream and video stream would be massively improved.  If the camera is within a few feet of the computer you can get an HDMI interface for the computer.  If not an SDI to HDMI converts and you can run as much coax as you need.  I think you can squeeze that in your budget.
Keep in mind the Flow 8 needs a tablet to access many of the eq and dynamics settings.
Herman Wolf
« Reply #6 on: April 02, 2022, 04:33:15 PM »
Yeah, they've been using OBS for a couple of years, now, in the main sanctuary, where they have a dedicated streaming rig on the balcony. I came in and tweaked the audio processing for them last year while their AV contractor was in tweaking the house system and updating Q-Sys Designer (which I've trained myself on since).
The plan is to get the whole rig to live by the (soon-to-be-wall-mounted) camera in the back of the room specifically in order to minimize the need for format converters and long cable runs all over the place. I'd probably spec an HDMI cable from Blue Jeans Cables because I like that company's vibe (and their Monster Cable lawsuit story is endlessly entertaining).
Yes, well aware, thank you.
Herman Wolf
« Reply #7 on: April 02, 2022, 11:30:03 PM »
I looked at those. The cheapest ZonePro is twice the purchase price of the Flow 8 plus there would be additional installation costs for the control knob(s). Also, the Flow 8 has USB which could come in handy in a number of scenarios.
If the mixer doesn't work out, e.g people kept getting the faders confused, then I'd probably push them to have control knobs installed and buy a zone processor instead.
Mike Caldwell
  • Covington, Ohio
« Reply #8 on: April 03, 2022, 12:13:12 AM »
I knew it would be more expensive but it could be set up with only a volume knob exposed, actually with it all set up and dialed in you may not even need a volume knob!
« Reply #9 on: April 03, 2022, 03:00:42 AM »
Sounds like you have a great handle on your tech.  I have some Blue Jeans cables at home, I am sure the HDMI will work just fine at that distance.  If you run the OBS on Linux I am going to think you are a ringer.
Page created in 0.14 seconds with 24 queries.
