Author Topic: Extending stage ties/snake  (Read 1787 times)
Matthias McCready
« on: March 12, 2022, 06:10:29 PM »
Hey All,
So the venue where I work got partially remodeled. I got a new PA (woot woot), but that was about it (not a pretty engineering room).
So I am wanting to extend and rebuild what is coming off the stage. I probably don't have enough time to pull new cable, and things are working.
Goals:
1) Current cabling tails are install grade, want to have better quality tails with strain relief (current stuff has none).
2) I need to extend the cable's about 10-15ft (into a rack and out over or below my stage box)
So what I was thinking of:
1) Belden 8412 for cabling (I have some nice number Nuetrik's with colored boots already for the ends.
2) Tech Flex FLEXO PET (.25 inch size) that corresponds to boot color and staging.
So my questions:
1) If you were doing such a project what materials would you use? I want to do things right.
2) What is the best way to connect and extend 60+ XLR cables? A coworker suggested something like this . Is that a good direction?
3) Anything I am missing?
Thanks!
Matthias McCready
Measure twice, and cut once; this is especially important if you are a mohel.
Mike Caldwell
  • Covington, Ohio
Re: Extending stage ties/snake
« Reply #1 on: March 13, 2022, 12:13:00 PM »
Are these tails something that gets disconnected, moved, rolled up ect. or just a fixed connection from point A to point B and left in place?
What need strain relief?
From the sound of it I'm thinking it's more a point A to B fixed connection.
How are the end of the existing cables terminated at this time?
If it's just a fixed, put it in place and there it stays something like West Penn 454 would be fine.
Post a picture of what your working with.
Matthias McCready
« Reply #2 on: March 13, 2022, 09:32:08 PM »
I don't have a picture of things, I will try to get one later this week. I do have a picture of a similar setup (close to what I am trying to achieve).
These are cables coming from various pockets around the stage, so I have 60ish male XLR connectors from stage.
So cables get moved as I patch different things in different places. For example if an electric player is using an amp, or playing on a different side of the stage etc. I keep the head-amp the same so that it is consistent inputs for the session files and multitracking.
Previously all the cable ran into an analog snake on the wall, recently I put the digital stagerack in engineering. So the cables have to reach to that rack, which is farther than where they landed previously and it is not tidy.
So I am wanting to extend the cables and to feed them through the stage rack, similar to the linked picture.
Hopefully that helps to clear it up some?  :)
Thanks!
Matthias McCready
Caleb Dueck
« Reply #3 on: March 14, 2022, 12:46:43 AM »
What about solder the existing install-grade cables into the back of a tech plate, and then just order some fan to fan snakes?  I'm doing something similar currently at another church.  A 16"x16" or so custom plate and NEMA box aren't too pricey, and snakes can be Elite Core on up to nice Whirlwind/Rapco/etc.
Mike Caldwell
  • Covington, Ohio
« Reply #4 on: March 14, 2022, 07:17:35 PM »
I was thinking along those same lines, a patch panel of sort.
Unless you truly have a big boy 60 input stage you could use a smaller patch/jumper snake of the number of channels on the stage box and then just patch into the stage inputs as needed on the patch panel, that would also save on wear and tear of your stage box connectors.
Matthias McCready
« Reply #5 on: March 17, 2022, 03:29:31 PM »
Alrighty, here are some photos of what I am working with.
The 1st photo is the wall where I have 64 lines coming in from the stage.
The 2nd is of the stage rack where I am wanting everything to land.
I have a cable ladder already installed up the wall, and to the rack For things to run.
On the plus side I do already have a large plate on the wall above the cables that was used for wedges in years past, so I could have a new plate made; however I don't feel like this makes the area any cleaner, I would still have some intense cabling going on for a few feet, and FWIW the bean counters probably don't want to purchase a whole gangle of sub snakes.
64 inputs  :P
I am not opposed to an additional patch panel; however I would want it in the same rack as well and it would take up space. While it would be pretty, I don't know if would add enough functionality to justify it.
So I guess I am coming back to what are the better methods for connecting a plethora of XLR cables.
Thanks for the help!
Matthias
Paul Johnson
  • Currently - Lowestoft - UK
« Reply #6 on: August 31, 2022, 11:39:39 AM »
I'd be happy with a number of 8 ways. With decent connectors. I guess I might consider mesh strain relief, but if they were mainly going to be undisturbed I'd probably not bother. My favourite install type cable for this kind of thing was sourced from Canford Audio in the UK to the BBC specs, and they were the BBC's main source of this kind of multi - easily stripable outer and individual screened and sheathed. I'd still use their cables over any speciality cable, but they do sell quite a lot of Belden now, I note - probably cheaper than making their own.
Brian Jojade
« Reply #7 on: August 31, 2022, 03:43:25 PM »
So it appears that the current setup has the cables already terminated to XLR connectors, and you need them to be extended about 15 feet to where you want to move your stage box.
The super easy answer would simply be just XLR connectors to the extension.  Bundle as needed.  If one of the extensions gets damaged from moving around, you can simply replace it.
An XLR connector should be as good as any other solution that would extend your existing cables, although not as tidy as a patch panel at that location.
Alternatively, terminate the cables to a patch panel and then create your jumpers again as needed.
Using multi cable snakes might be a little less unruly, but individual cables bundled in groups wouldn't be too bad, especially if you're not moving the entire thing at once.
The stuff that moves around regularly should definitely have braided shielding.  Stuff with spiral shield or foil shield is fine for an install, but excessive movement can cause the shield to break down over time.
If you're extending to a new patch panel and will then use jumper patches, the extension can be of regular install type cable.  There's no real advantage to using more expensive cable for that purpose.
If going to a patch panel, you can either use the old school 1/4" panels, or you can just terminate to an XLR panel and use traditional XLR patch cables.
Using the 1/4" panel, you can create a 'normal patch' that would operate without any external patch cables connected. You would then just insert patch cables when you need to move stuff around.  If you use an XLR panel, you'll have 64 patch cables always there plugged in.  Potentially a bit messier.
Brian Jojade
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
« Reply #8 on: August 31, 2022, 11:14:34 PM »
I would be inclined to terminating your current wiring into some of these terminal blocks:
https://www.mouser.com/ProductDetail/Phoenix-Contact/3240172?qs=QIXfRiWXAy6UhzxmZollig%3D%3D&mgh=1&gclid=Cj0KCQjwjbyYBhCdARIsAArC6LJ1cEDg4eGQ575rGyHXXda5pRq-W2gvl3Wizfz_3L3v70sCu93cPBUaAmKKEALw_wcB
And then coming out the other side if the blocks with install cable long enough to reach your input rack.
All of this could be installed inside a metal enclosure and either techflex the whip or bundle it in 8 channel groups, or whatever makes you happy. Of course using proper strain relief as you leave the enclosure.
Nothing wrong with making your own whip out of install wire. It's tough and stands up to abuse pretty well. You just have to make it tidy with heat shrink and tech flex, etc.
Page created in 0.057 seconds with 25 queries.
