Author Topic: Crossover replacement  (Read 545 times)
Jason L Holland
« on: March 12, 2022, 03:23:52 PM »
Wonder if you folks can help. I got a donated Portable PA system (Behringer Eurolive EPA900) that I want to re-donate to my kids elementary school. Problem is one of the speakers has a tweeter out. Looks like it's in the crossover. Here's what I've done.
Tried known good tweeter in the speaker - no joy - Test voltage coming to HF leads - zero voltage) - Reflowed all the solder joints on the crossover and inspected for obvious damage - no joy -
The LF speaker works fine so it seems like it's something in the HF part of the crossover.
Behringer doesn't sell a replacement crossover and only recommend replacing the entire speaker.
Thoughts on what I should do next? I was thinking maybe getting a 2 way crossover from amazon or ebay and just trying it to see. I guess I could test each componet and replace but not sure if it's the pcb board so...
How do I choose a comparable crossover to what I have? The speaker is a 10" LF woofer and 1.35'' aluminum-diaphragm compression drivers. The amp is 450watts per side.
so Would I be good to try something like:
https://www.amazon.com/Durability-Crossover-Frequency-12-18inch-Professional/dp/B08D3SVVXM/ref=sr_1_4?crid=20S1O6P8AF36K&keywords=2+way+crossover+500+watt&qid=1647116375&sprefix=2+way+crossover+500+watt%2Caps%2C42&sr=8-4
It just needs to be 500 watts or so? Should I worry where the crossover point is? It's just gonna be used for music and speaking mostly.
Thanks for any help!
Dave Garoutte
  • San Rafael, CA
Re: Crossover replacement
« Reply #1 on: March 12, 2022, 05:11:18 PM »
Read the forum rules!  No one will respond until you change your handle to your real name.
Page created in 0.092 seconds with 24 queries.
