Pages: 1 [2] 3 4 5   Go Down
Author Topic: Column PAs  (Read 5353 times)
Phil B
Re: Column PAs
« Reply #10 on: December 27, 2021, 02:35:12 PM »
Doing some more reading over the last few days I've moved away from the portable PA / complete set type columns to the larger, more standalone models with separate subs such as dB Ingenia, RCF NX L24, JBL CBT & FBT Vertus.
Having never worked with these column types before, how would they compare to traditional point source boxes, such as Yamaha DXR12s? They obviously have smaller woofers, although more of them. Anyway, I'd really appreciate your thoughts.
Sent from my MAR-LX1M using Tapatalk
Steve-White
  • Fort Worth
Re: Column PAs
« Reply #11 on: December 27, 2021, 03:24:31 PM »
^^^ You're headed in a good direction sir.
Doug Fowler
  • Saint Louis, MO USA
Re: Column PAs
« Reply #12 on: December 27, 2021, 04:25:10 PM »
Yamaha and other direct radiating designs will have zero pattern control or close to it below the crossover point, where the HF horn is out of the picture.   Thatís a bad thing in an acoustically challenged space.
Brawndo, the Thirst Mutilator.
It's got electrolytes.
It's got what plants crave.
lindsay Dean
Re: Column PAs
« Reply #13 on: December 28, 2021, 01:12:54 PM »
Pictures and proposed seating layout of the room would help greatly.
     and Pray for higher guidance
Phil B
Re: Column PAs
« Reply #14 on: December 28, 2021, 01:18:01 PM »
Hi Lindsay. Thanks for your input. I think the key questions are how the various column  / tall thin speakers compare to each other, as well as to more traditional point source speakers.
Caleb Dueck
Re: Column PAs
« Reply #15 on: December 28, 2021, 06:37:48 PM »
If this is for an installation - you just completely missed the most critical detail.  How a speaker 'sounds' is low on the list compared to dispersion pattern and pattern control.
Phil B
Re: Column PAs
« Reply #16 on: December 28, 2021, 11:12:34 PM »
How does the dispersion pattern and pattern control of a modern column speaker (eg dB Ingenia 1T) compare to a traditional point source speaker?
Doug Fowler
Re: Column PAs
« Reply #17 on: December 28, 2021, 11:41:23 PM »
Do yourself a favor and run some models.
Phil B
Re: Column PAs
« Reply #18 on: December 28, 2021, 11:50:31 PM »
Yeah, that seems my only option. Was hoping the forum would help narrow the field, but I guess I'll have to try source as many models as I can in the new year.
Doug Fowler
Re: Column PAs
« Reply #19 on: December 29, 2021, 12:08:06 AM »
You already have most of what you need to know courtesy of this forum but Iím not sure you realize it.
Find your local distributors for demos.
Re: Column PAs
¬ę Reply #19 on: December 29, 2021, 12:08:06 AM ¬Ľ
Pages: 1 [2] 3 4 5   Go Up
Page created in 0.046 seconds with 24 queries.
