Author Topic: Setting IP gateway for Lab Gruppen amp.  (Read 645 times)
Phillip Ivan Pietruschka
« on: July 04, 2021, 06:20:42 AM »
Does anyone know if itís possible, and how, to set the Gateway for the Control ETH port on a D10:4L (or presumably other recent lab amps, since they share the Lake control software)?
Said software exposes the IP and Subnet for setting; but not the gateway. So I have a strange conundrum where I cannot access the control ETH from outside its local subnet/vlan; but I can access (Ping) the Dante ETH, which as Iím sure many of you know isnít much use from outside the local subnet.
The very same software is high in the running for my least favourite UI ever
Re: Setting IP gateway for Lab Gruppen amp.
« Reply #1 on: August 06, 2021, 04:24:55 PM »
In case anyone is looking to do this in the futureÖ This can not be done statically via Lake Controller, but it can receive and use a Gateway via DHCP. I wish MT/Lab Tech support had been able to tell me that, would have saved some stuffing round.
Luke Geis
« Reply #2 on: August 06, 2021, 07:08:09 PM »
I use the LA series a bit and I have not had much luck integrating the control software through any sort of network switch or router. Some of it may have to do with DHCP vs. Static settings. I have not tried getting crazy yet, I tend to just bring another dedicated laptop to run the Lab Network with and run all my other GUI's on another one.
« Reply #3 on: August 06, 2021, 11:49:56 PM »
Luke, the inability to set a gateway almost certainly explains your failed attempts to use the control software on a routed network. It seems extremely shorted to me that they neglected to expose this parameter - itís not exactly the bleeding edge of networking technology.
¬ę Reply #3 on: August 06, 2021, 11:49:56 PM ¬Ľ
Page created in 0.082 seconds with 25 queries.
