Author Topic: Sprinter van radiator fan wiring?  (Read 444 times)
W. Mark Hellinger
« on: June 28, 2021, 05:30:22 PM »
I'm hoping somebody here's been there done that concerning wiring in a manual "on" switch for the electric radiator fan in a Sprinter van?  I'd dearly like to do that to my 2006 Sprinter (diesel): be able to electively turn that fan on before the computer thinks it needs it, because the computer's idea of when the extra cooling per the electric fan is appropriate is crazy hot... something like 235 degrees.  I'd just as soon kick that fan on when the heat gauge starts creeping up past 210, or when I know it's 100+ out, like it is today, and I know the van is loaded to the gills, and I know I'm about to pull a 5 mile long 5% grade... like I know I have to do repeatedly this summer.  I thought I had a cleaver method of splicing in a switch to the thermostat sensor plug... because unplugging that connection forces the fan on, but then if I break that circuit with a switch, I'm guessing the temp gauge quits working... and I'd just as soon have that gauge working if I'm concerned enough about the engine getting hot that I elect to turn on extra cooling.  I understand the radiator electric fan relay is under the driver's seat... and I'm thinking I could maybe switch activate that relay, but I'd just as soon switch the low amperage side as force feed the 30 amp pos. side feeding the fan, but I don't know if the low amp side is 12v DC activated or what... might be some computer square wave information signal, I don't know.  And "no", my Sprinter doesn't have AC, so I don't have that option to kick on the aux radiator fan.
Re: Sprinter van radiator fan wiring?
« Reply #1 on: June 28, 2021, 06:01:21 PM »
with a VOM you should be able to determine the fan voltage on/off.... measure voltage with fan running and stopped to see if it uses a high side switch or low side.
You should be able to use steering diodes to override the standard control wiring, without breaking anything.
Craig Hauber
« Reply #2 on: July 03, 2021, 12:04:43 AM »
Are you sure your temp sensor is operating correctly?
I had a Crown Vic that thought it was 15 cooler than it really was.  Changing out the sensor fixed problems like you are describing.
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Chris Hindle
« Reply #3 on: July 03, 2021, 01:16:34 AM »
There are probably 2 sensors. One for the fan relay, and one for the temperature gauge on the dash.
Which one is not accurate?
THAT is the question.
A visit to the Mother Ship may be wise before you alter the wiring yourself.
Chris.
Dave Pluke
    • BIGG GRIN Productions
« Reply #4 on: July 04, 2021, 12:00:16 PM »
Reminds me of a rental car I once had in Mexico. A Nissan Tsuru (pretty sure that translates to "dog" in english) was pegging the temp gauge.  I brought it back to the airport lot, the guy opened the hood, disconnected the sensor wire and said; "All good now". In fairness, it did last the remainder of the week.
Dave
lindsay Dean
« Reply #5 on: July 06, 2021, 01:37:33 PM »
The thing about temperature regulated fan relays is that the fan is not designed to be run when you're over about 15 miles an hour it will eventually damage the fan motor
     and Pray for higher guidance
Page created in 0.062 seconds with 24 queries.
