Author Topic: Shop Safety  (Read 879 times)
Steve-White
  • Fort Worth
Shop Safety
« on: June 20, 2021, 05:38:17 PM »
I was out in the shop this afternoon working on a mounting panel for a Lian Li computer case to hold the power supply.  Did a full refresh on the audio workstation PC - motherboard, processor, RAM, video card, power supply, SSD's and liquid cooling + a second DVD/RW drive.
Anyway, cleaning up the 1/8" aluminum panel on the 6x48" belt sander after cutting to size on the band saw.  The belt flew apart on the sander.  That's the second time that's happened on that machine in the last 3-6 months and only the second failure of that nature I've ever encountered.
Fortunately, I was wearing a full face shield and work gloves when it let go.  It ka-bangs real good with a 1.5 HP machine at full RPM with belt moving, rollers spinning, motor spinning, sanding disc spinning.  Scared the crap out of me - fortunately nothing hurt.  The tracking has be a little strange with that machine for quite some time.  Not sure if that was a factor or not or if it's the brand of 6x48" belt.
Ordered a new disc/belt sander:  https://www.zoro.com/jet-beltdisc-sander-1-12hp-115230v-jsg-6dc/i/G4283986/
Pretty decent looking machine, and cost ~3 times what I paid for that old Craftsman 20 years ago.
Pictures attached.  Be safe guys, I'm real happy I was wearing heavy gloves and the face shield - that thing could take an eye or finger real easy.
« Last Edit: June 20, 2021, 05:43:10 PM by Steve-White »
Steve-White
  • Fort Worth
Re: Shop Safety
« Reply #1 on: June 20, 2021, 05:42:18 PM »
Picture attached.
Dave Garoutte
  • San Rafael, CA
Re: Shop Safety
« Reply #2 on: June 20, 2021, 06:44:31 PM »
Picture attached.
Sanding belts often have a direction to them.  The overlap can peel if reversed.
That looks like a new belt.  It also looks like your panel dug in, ripping the belt.
I usually use the disc sander with thin materials.  No way of digging in.
Steve-White
  • Fort Worth
Re: Shop Safety
« Reply #3 on: June 20, 2021, 06:59:16 PM »
Directional belts with arrows on them are definitely what I'm used to.  Seems like the latest fad, after peel and stick and hook and loop is non-directional belts.
Could be the edge of the plate caught and dug in.  I've done edge sanding for a long time and not had any problems until the last two incidents.  Maybe just dumb luck there.  The belt is industrial grade from Grainger, but a they are no-name house brand it looks like.  I usually use 3M or Norton abrasives.
Gloves & face shield always for this guy.
Bob Stone
Re: Shop Safety
« Reply #4 on: June 20, 2021, 07:37:32 PM »
Gloves are a bit risky on anything moving like that...all it takes is a thread to catch and pull your hand right in. Most advise not to wear gloves while sanding with anything powerful.
Steve-White
  • Fort Worth
Re: Shop Safety
« Reply #5 on: June 20, 2021, 07:42:21 PM »
Definitely on a drill press gloves are a no-no.  For the belt sander, that's a risk I'll take as getting into that belt with a bare hand could be unpleasant.  Probably just need to limit the free-styling I so like doing.  :)
Once I explained to the panel who it's biological daddy is, things went better.  Should have started out on the mill as i need to do some cutout work on the mill anyway.
I'm thinking the belts themselves are questionable in the sander.  Once the new machine shows up, we'll find out.  I have a smaller 4x24" machine and do that kind of work on it frequently without issues.  I do a lot of work on sanders, why there's a dedicated table full of them in the shop.  Plenty of modeling things to include boat propeller balancing and sharpening as well as stainless steel turn fins and never had problems.  For the props it's a 2" wide belt in free air but they are hand held.
« Last Edit: June 20, 2021, 07:56:23 PM by Steve-White »
Chris Hindle
Re: Shop Safety
« Reply #6 on: June 21, 2021, 12:39:39 AM »
Far too many "shop accidents" are not accidents, but lapses in procedure and/or attention.
Glad you had adequate protection in place.
It's been a few years, but i have never seen a belt without a direction arrow either.
By chance, were both belts from the same batch? Might be a QC problem, but likely you "caught an edge".....
Chris.
(Lots of stupid stuff, but still have 10 fingers and 2 eyes, and no extra holes.......)
Stephen Swaffer
Re: Shop Safety
« Reply #7 on: June 21, 2021, 01:26:52 PM »
Years ago, I had a co-worker loose a portion of his thumb when the glove he was wearing was sucked into a disc grinder.  These tools are not idiot proof-or even forgiving if you get complacent for a split second.
Steve Swaffer
dave briar
  • Helena Montana
Re: Shop Safety
« Reply #8 on: June 21, 2021, 02:16:04 PM »
Fifty years ago I learned finish carpentry from one of the nicest, most intelligent, and engaging humans Ive every crossed paths with. We talked endlessly throughout the day about science, literature, music, you name it. But gentle Richard had one absolutely inviolable rule: Before a power tool is started and during its use there will be no talking by anyone on his crew. I flipped a table we saw on once while finishing my sentence and he calmly walked over and turned it off. That was my one calmly delivered warning. Never did it again.
..db
Steve-White
  • Fort Worth
Re: Shop Safety
« Reply #9 on: June 21, 2021, 04:33:31 PM »
Plenty of stupid screw-ups here over the years and fortunately no major boo-boos.  I remember drilling a 1/8" hole into a model boat part years ago.  Back when hand-held drill motors had cords on them.  Bit snapped from excess pressure and remaining part drilled through the end of middle finger - ouch.  A bit more careful drilling holes now.
Steel to boots in shop always and pay much more attention to safety.
More forensics this morning and those that stated "it caught an edge" are awarded the prize.  Sure looks that way - at the main failure point of the belt there is an indention that looks to be 1/8" wide.
Won't be doing that anymore.  :)
« Last Edit: June 21, 2021, 04:42:59 PM by Steve-White »
Re: Shop Safety
Page created in 0.242 seconds with 22 queries.
