Author Topic: Spray-in insulation and acoustic absorption  (Read 596 times)
John Hiemburg
« on: June 14, 2021, 06:39:42 PM »
Afternoon,
I've spent some time searching, and either this information is hard to find or I'm failing in my search.
We're building a metal building (16,000sf) to house a new sanctuary on the current church campus. Metal pre-fab. It will be exposed ceilings. The metal building mfgr recommends spray-in expanding foam insulation for its insulating properties, but I can't find any information on sound absorption for any of the available products.
I *can* find info regarding spray-in foam and sound *transmission*. In other words, there is a healthy amount of discussion about whether it is useful to stop sound from getting between rooms. This is not my concern. I just need to find some kind of data regarding absorption - I can pass that along to the acoustical consultant to design the proper amount of absorption for our room.
Am I missing a magical search term? Does anyone have any experience with this? Any other concerns or 'gotchas' with this kind of insulation that you've experienced?
Thank you!
Dave Garoutte
  • San Rafael, CA
Re: Spray-in insulation and acoustic absorption
« Reply #1 on: June 14, 2021, 07:00:33 PM »
Afternoon,
Thank you!
The other advantage of the foam, is the irregular surface, helping break up and disperse reflections.
Bob Stone
« Reply #2 on: June 14, 2021, 07:35:04 PM »
As far as I know, there's no spray foam that can be left uncovered on its own due to the noxious fumes if it ever catches fire. So what are they intending on putting over it?
John Fruits
« Reply #3 on: June 14, 2021, 11:24:53 PM »
Have you asked your acoustical consultant?
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
Erik Jerde
« Reply #4 on: June 15, 2021, 12:54:29 AM »
Thereís a few questions that need to be addressed.  First, like Bob noted spray foam in occupied spaces usually needs to be covered.  Iím not sure how this rule changes for commercial from residential.  When in doubt check with AHJ and mfgr specs.  Lacking a specific code citation mfgr specs win.
Second, what type of foam and to what thickness?  All my experience has been with closed cell foam but there is also open cell foam used in some situations.
Based on my experiences with closed cell foam Iíd expect it to perform like an irregular hard surface.  Fully cured closed cell is quite hard.  Of course you can dent it but I walk on 6Ē of closed cell in my attic with no worry about punching through or otherwise damaging the finished ceiling below.  Stuff is strong.  Definitely is not an absorptive surface.
Lastly, as far as the acoustician.  This is their job to figure out.  Thatís part of what youíre paying them for.  You should just be able to set out what you want the room to perform like and they should be able to figure out how to accomplish that.  Of course getting the budget to properly build the design is another thing entirely.  Hopefully youíve got a good acoustician.  I worked on a project a couple years ago where the building committee went against my advice on acoustician and now the back wall acoustic panels are reflective instead of absorptive.  Ugh.
Brian Jojade
« Reply #5 on: June 15, 2021, 12:59:51 AM »
The spray foam should help prevent the metal structure from rattling with sound. However, as others have said, you're replacing one hard surface with another.  While the irregularities will potentially redirect some of the higher frequencies, it's not going to absorb much at all.  And if you cover it with another material, it isn't going to have that much impact in the sound within the room.
Brian Jojade
Neale Watson
« Reply #6 on: June 15, 2021, 06:54:24 AM »
May I suggest that the term sound 'absorption' is misleading.  I'm being picky, but better to stick with the terms 'reflection' and 'transmission':
Soft or irregular surface will minimize reflection;
Soft or irregular surface on thin backing will minimize reflection and do nothing to stop transmission;
Thick and dense material will stop transmission;
Soft or irregular on top of dense material will minimize reflection and transmission;
Dense material with soft material behind it will minimize transmission, but do nothing to minimize reflection
Foam behind a panel helps if it removes air gaps, but otherwise does not 'absorb' sound.
« Last Edit: June 15, 2021, 07:32:53 AM by Neale Watson »
Caleb Dueck
« Reply #7 on: June 15, 2021, 07:05:39 AM »
This here.
Chris Hindle
« Reply #8 on: June 15, 2021, 07:51:03 AM »
Is the foam to be used to fill a void between inner wall and outer wall, or just as a covering to the inner side of the only wall?
Is the manufacturer intending for an inner "finish" wall to be applied after erection of the pre-fab components?
Any metal left exposed (ceiling) WILL be an acoustical problem.
Chris.
John Hiemburg
« Reply #9 on: June 15, 2021, 01:13:05 PM »
Erik, et al, good points all around. I will look into the question of leaving the foam exposed - it was suggested by one foam manufacturer that it could be painted (good for me) but no mention of it needing to be covered because of fumes/etc. I'll look into it.
As for the acoustician, right on all counts. We have relationship with an excellent company in Australia that has worked on some recent projects for us, and will consult on this one as well. I would like to know and understand for myself going into it. Also at this point insulation is a sizable budget line-item so choosing spray in vs soft goods is an important decision. Having an idea if it is helping or hurting at this stage will certainly help with the math.
Thank you!
¬ę Reply #9 on: June 15, 2021, 01:13:05 PM ¬Ľ
Page created in 0.074 seconds with 23 queries.
