Pages: [1] 2 3   Go Down
Author Topic: Lighter weight sub?  (Read 2150 times)
Dan Godwin
Lighter weight sub?
« on: June 14, 2021, 12:45:58 PM »
After two gigs this weekend that required 17+ stairs, Iím considering some lighter subs.  Iím not as young as I used to be and Iím definitely feeling it in my back.  Iíve been using 2 Yorkville LS701p which weigh in at a measly 95lbs.  Any recommendations?  Should I just hire some strapping young lads to do the grunt work?  Thanks!
Re: Lighter weight sub?
« Reply #1 on: June 14, 2021, 01:13:01 PM »
is it just the weight that you are interested in?
Or does freq response and output SPL matter to you?  or something else?
Does it need a pole cup?  Remember that a lightweight base can easily tip over, depending on the top you have on it.  Does that matter?
Knowing the actual needs will help to get useful responses.
Dan Godwin
« Reply #2 on: June 14, 2021, 01:18:19 PM »
Thanks Ivan.  I knew as soon as I posted, I shouldíve added more information. Weight is the primary reason for considering something else.  Iíd assume the Frequency response can only get better from the band pass sub Iím using now. Iíd like similar output if possible but recognize that may not be possible.  Pole cup is nice but not 100% needed. Iím currently using DSR12 for tops. Thanks!
Paul G. OBrien
« Reply #3 on: June 15, 2021, 11:52:51 PM »
Is that sub really as loud as the specs state? Being a bandpass I anticipate it having a giant peak like response and for that reason I have always dismissed it thinking it will be a one note wonder.
Yorkvilles PS15s is a fantastic little sub with impressive output for such a small box, I find it easy to move compared to the es18p for example, but it's only a few pounds lighter than the old ls701 so not much help there. On paper the ps15s has 5-6db less continuous output than the LS701 but if the old bandpass doesn't have a very flat response then the PS15 may actually out perform it... and sound a lot more musical.
There are 15" powered subs from all the usual brands that could be substituted but the obvious selection to pair with DSR's would be one of the DXS bandpass subs or a new XLF model.
« Last Edit: June 16, 2021, 12:07:28 AM by Paul G. OBrien »
Brian Jojade
« Reply #4 on: June 16, 2021, 03:34:51 AM »
I doubt there is much on the market that's going to offer a significant weight reduction and still give the performance needed.  A 70lb box vs a 90 lb box still is too much to drag up stairs alone at any age.  These should be 2 person loads.
Now, you might be able to save some strain by getting a stair climber dolly, but up and down more than 1 or 2 stairs, I'd insist on more people doing the job.
Brian Jojade
« Reply #5 on: June 16, 2021, 11:38:36 AM »
You don't need a lighter sub - 20 lbs won't make a significant difference with 17 steps- you need a helper AND bill the client for that person.
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #6 on: June 16, 2021, 01:38:56 PM »
Bandpass designs can sound as good (or bad!) as any other. I built one a little while ago (the chosen drivers practically forced a 4th order bandpass), and it sounded great once properly integrated.
A "gotchya" is that the bandpass forms its own acoustic crossover slope at the top end, so you've got to factor that in when programming your processor. A 12dB/octave Butterworth (electrical) slope might get you a resulting 24dB/octave Linkwitz-Riley.
There are plenty of badly-designed bandpass subs, and plenty of well-designed ones being used badly.
I quite liked the 4th order bandpass for the following advantages:
- No particular need for an infrasonic filter - it would provide some output at 10Hz on account of the sealed back chamber.
- With a pair of drivers, you can set the internals up for force cancellation. Bonus points if you get the port(s) passing cool air directly over the magnets.
- Smaller than a well-aligned ported box
- Lots and lots of output, albeit not going as low as a bigger ported box.
A double-edged-sword is that the acoustic bandpass filters out most of the distortion from the drivers. The sound stays pretty clean until the drivers are seriously struggling (and likely about to fail).
Chris
www.grimshawaudio.com
Steve-White
  • Fort Worth
« Reply #7 on: June 16, 2021, 02:10:12 PM »
This +1.  They pay for stairs.  (period)
Brian Jojade
« Reply #8 on: June 16, 2021, 03:08:28 PM »
And when the client complains, tell them to take it up with the venue that didn't have roll in access to their space available. Any other business has additional charges for this sort of thing. We need to be able to do exactly the same thing.
Brian Jojade
Steve-White
  • Fort Worth
« Reply #9 on: June 16, 2021, 06:08:53 PM »
Exactly or move his event(s) to a venue with proper access.
¬ę Reply #9 on: June 16, 2021, 06:08:53 PM ¬Ľ
Pages: [1] 2 3   Go Up
Page created in 0.056 seconds with 25 queries.
