Author Topic: Podium mic on off switch on pressure floor pad  (Read 418 times)
Roger Talkov
« on: June 09, 2021, 04:32:08 PM »
All,
I am sure this has been invented or discussed before but I cannot find it.  Does anyone know of a pressure sensitive mat that can be placed on the floor at a podium  that would unmute and mute a microphone lets say for a HOW or similar? We have a customer that wants this functionality and I just don't have a solution in my back pocket where I usually find things like that.
Ideas? Thoughts?
Milt Hathaway
    • http://www.fitzcosound.com
Re: Podium mic on off switch on pressure floor pad
« Reply #1 on: June 09, 2021, 04:50:26 PM »
Wire a pressure sensing alarm door mat in place of the red momentary talk button on this: https://www.avlifesavers.com/multisw.htm
Milt
FitzCo Sound, Inc.
Midland, TX
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #2 on: June 09, 2021, 05:09:41 PM »
All,
Ideas? Thoughts?
This was talked about extensively over on the Syn-Aud-Con forum a month or two back.   I didn't follow it closely because I don't have a similar use case, but there were a lot of different ways to skin the cat if I remember.  You do have a be a member to view that forum though.  $30 buys you a year.
https://www.prosoundtraining.com/
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Keith Broughton
  • Toronto
« Reply #3 on: June 10, 2021, 06:54:47 AM »
I don't know about switch mats but there is a device available that uses a proximity detector to sense when someone is close to the mic and inserts on the XLR line.
Here is an example...
http://www.optogatesolutions.com/
Caleb Dueck
« Reply #4 on: June 10, 2021, 02:47:31 PM »
All,
Ideas? Thoughts?
Most pressure mats I believe are essentially a contact closure device.  If it goes into a DSP, it's pretty simple with a bit of logic (contact wire close mutes the mic input).  If going into a console rather than a DSP, talk with RDL, or look into the Radial Relay XO and floor mat.
Page created in 0.057 seconds with 24 queries.
