Author Topic: Effects On Behringer P16?  (Read 1384 times)
Toby Marks
« on: May 10, 2021, 01:42:02 PM »
Hello,
    Is it possible to have effects on the Behringer P16's? Right now there is a dry signal, is there a way to have it come out the way it is coming out of the house with the reverbs and delays?  Thank you.
Chrysander 'C.R.' Young
  • North Central FL
Re: Effects On Behringer P16?
« Reply #1 on: May 10, 2021, 03:11:38 PM »
Short answer: yes.  Probably the best way to do it is to take a spare aux mix and send the desired amount of efx into it and then map that aux to one of the channels on the P16.  That said, I have found effects in iems and monitor mixes can often lead to intonation issues with singers.
Toby Marks
« Reply #2 on: May 10, 2021, 03:53:01 PM »
Thanks for this! I will go ahead and try that.  The intonation part makes sense. We only have the band using the P16's and the vocalist are using floor monitors for now.
  • North Central FL
« Reply #3 on: May 10, 2021, 05:05:27 PM »
Toby,
Good luck and update us when you try this.  Personally, I tend to set up the P16 for worship something like this:
16 - click track.
15 - backing track(s) - if you are using multiple tracks, sum them into a bus and assign it here.
14 - EFX aux mix (usually Aux 12)
13 - Drums (mix them onto Aux bus 11)
Use the other 12 as needed.  I try to have Vox 1-4 and then the other instruments as needed.  I am a bit OCD, so I try to match channel numbers with the P16 channels, to a point, and print out little strips with the channel descriptions and tape them to the P16s.
Then, have all your musos watch this video:  https://www.youtube.com/watch?v=zBeCasZhwCg
Page created in 0.041 seconds with 22 queries.
