Author Topic: What mic for audience comments?  (Read 2733 times)
Bill Jones
« on: April 29, 2021, 09:40:27 AM »
When we live stream, we have a session where the audience has comments. We are currently carrying a wireless mic to each person, but that has some challenges when it is hard to reach someone in the middle of the row. I would like to add a shotgun mic or some other type ?? that we could mount at the front and leave it there, and point it toward the pews to pick up anybody that has comments. Our building is 50 feet wide and 80 feet long. Any suggestions?
Stephen Swaffer
Re: What mic for audience comments?
« Reply #1 on: April 29, 2021, 12:59:44 PM »
I'm not sure the specific mic is all that critical.  I am using a Shure SM81 (primarily because it sounded the best of what I had available) for ambience in our building.  Due to the acoustics of the building-it is an old (1860's) vaulted ceiling with the peak running opposite of what you would expect-I simply put it at the front and pointed it at the big "reflector" in the back.  It works surprisingly well with one caveat-it is unbearable with "normal" program material-speakers/singers on platform.  Works well with congregational and if, say an usher, is praying from the congregation, but it creates a significant reverb otherwise.  Take away is, it needs to be  managed mic-not set and forget.
Steve Swaffer
Bill Jones
« Reply #2 on: April 29, 2021, 01:56:52 PM »
I didn't say this in my original post, but I assume I'll need two - one for each side of the center aisle. We would, of course, pull the sliders all the way down except when someone is speaking from out in the congregation.
Matthias McCready
« Reply #3 on: April 29, 2021, 03:42:45 PM »
You probably will not get better sound than using a mic as you are. Audience mics can work, but at the point someone is watching this stream on cellphone or laptop with tiny speakers the end result is that they will likely miss what the person is saying.
You can however simplify how people utilize the HH's, so instead of roving mics the following can be a good way to get participation:
1. Have people bring questions/comments to the front (ie have a Q&A mic upfront, sometimes having a moderator who can hold/pull it away is good depending on the circumstance).
2. Have people submit questions/comments digitally, then having a moderator/pastor etc read them.
(edited for clarity)
« Last Edit: April 30, 2021, 05:31:21 PM by Matthias McCready »
Measure twice, and cut once; this is especially important if you are a mohel.
Brook Hovland
    • DiA Events
« Reply #4 on: April 29, 2021, 08:21:09 PM »
Some ways to make that easier:
1. Have people bring questions/comments to the front.
Make sure the question is repeated for the stream audience.
Mike Caldwell
  • Covington, Ohio
« Reply #5 on: April 29, 2021, 11:25:10 PM »
If you do room fix mics do you plan to bring those into the PA and amplify it or only send it to the live stream?
Bill Jones
« Reply #6 on: April 30, 2021, 09:02:37 AM »
We would do both. We have separate sliders on our sound board so that we can control them separately.
Caleb Dueck
« Reply #7 on: April 30, 2021, 11:31:30 AM »
The loudest sound at the mic - wins.  Distance from mouth to mic is not your friend.
Lots of hanging mini-shotgun mics can kind of work, but that's expensive and ugly.
Bill Jones
« Reply #8 on: April 30, 2021, 03:13:45 PM »
I was hoping there was a magic bullet, but the more I think about this, the more I think shotgun mics is not a good idea. We will probably stick with what we have - roving wireless mic.
John L Nobile
« Reply #9 on: April 30, 2021, 05:07:53 PM »
As much as a pain roving mics are, they seem to be the best solution. I've seen mics taped to a pole to get them in the middle of the aisle. I think we use hockey sticks for that in Canada. :)
Page created in 0.048 seconds with 24 queries.
