Author Topic: DMX Light react to Audio Output  (Read 2295 times)
Paul G. OBrien
Re: DMX Light react to Audio Output
« Reply #10 on: April 03, 2021, 10:43:11 AM »
I don't think that controller will work, does it even have an audio input?
A controller like this is more like what you need... https://www.thomann.de/gb/adj_dmx_operator_384.htm
Although this one has some built-in FX that would produce better results with less programming.. https://www.thomann.de/gb/eurolite_dmx_led_color_chief_controller.htm
duane massey
« Reply #11 on: April 03, 2021, 12:40:37 PM »
For your specific needs, the headphone trick will probably be the simplest thing to try.
Duane Massey
Houston, Texas
Alex Reid
« Reply #12 on: April 03, 2021, 02:08:15 PM »
Well, maybe...  As you’ve already noticed your controller is only 12 channels, so you’ll have to use the light in 6 or 12 channel mode for things to work properly.  That being said, it doesn’t look like your controller is programmable in any way.  As mentioned above, you typically program scenes and chases into the controller that get cycled by audio.  I don’t see how this controller will work for what you need.
Sound-to-light usually picks up on bass more than anything else, but putting a headphone over the light’s mic is probably worth a try.
My logic behind the controller was well if the music slowed / beat dropped I could manually "control" the light and slow it down etc? Or is that not what a controller does? Sorry for all the questions!
Jeff Lelko
  • Cape Canaveral, FL
« Reply #13 on: April 03, 2021, 03:36:31 PM »
No worries about the questions - that's what we're here to help with.  So let me take a step back and try to explain a few things.  I'll be making several generalizations for the purpose of simplicity, but here's the gist on a lot of this:
Many DJ lights can run in three modes - auto, sound active, and DMX.  Auto mode just cycles through a series of pre-programmed chases or looks.  Sometimes the speed of the cycling is adjustable.  Sound-active mode cycles the light through (usually) the same set of programs but uses the bass in the music to trigger the cycles.  Some lights will automatically black-out or transition to a static look if there's a lack of music...others won't.  DMX mode foregoes all that for use with a DMX controller.
A DMX controller sends commands to light fixtures that translate into colors and movement from the fixtures.  The "decoding" will vary by fixture but DMX is an industry standard.  With any DMX controller you, the end user, will be required to program the various scenes, looks, and/or chases into the controller for playback during a show.  You gain significant advantages by doing this over using the fixture's internal chases since you can program the lights to look and move exactly how you want, but it takes time and skill to get everything to come out right.
The DMX controller can then playback the chases either automatically at the rates/times you've preprogrammed, can (in some cases) use music input or an onboard microphone to trigger the same chases based on the music, or can be triggered manually by the operator to sync to the music as best determined.  All professional operators use this last option or will have their lighting equipment triggered by timecode (or sometimes MIDI).
As mentioned in a previous post of mine, your expectations need to be very low to find sound-to-light triggering acceptable.  It'll work, but it usually has a very random and erratic look to it.  Your best bet is to program a variety of chases on a DMX controller and trigger them in real-time based on your music.  This will require the most work on your part but will also look the best.  If this is more scope than what you originally intended I vote to try the headphones and see what that looks like before spending more money.  Good luck!
Page created in 0.143 seconds with 24 queries.
