Author Topic: Easy Unsecured Low Quality Audio Over Network  (Read 1846 times)
Lee Douglas
  • 47.662615, -116.756954
« on: March 23, 2021, 05:33:18 PM »
Seems like this should be easy, but I'm not finding it.  I'm looking for a small cheap system that will encode audio at the head end and push it out over the LAN and amplified decoders on the field side that I can just "point" at the encoder.  Small amplifier for a couple of background music speakers.  70v or 4 ohm is fine.  Audio is low quality background music for a storage unit.  Security beyond what my network will already have is not important.  Looking for suggestions!  Thanks!
This space for rent
Hal Bissinger/COMSYSTEC
    • COMSYSTEC
Re: Easy Unsecured Low Quality Audio Over Network
« Reply #1 on: March 23, 2021, 08:13:57 PM »
Sounds like you are looking for IP speakers that are becoming popular these days. No, I haven't done any but I did find this from Axis who I know from security cameras. All POE, just run network cables to each speaker from a POE enabled switch.
https://www.axis.com/products/network-speakers
https://www.axis.com/products/axis-audio-manager-edge
So now you know what to look for. There are many others out there.
-Hal
Lee Douglas
« Reply #2 on: March 24, 2021, 11:05:07 AM »
-Hal
Thanks, Hal.  I do know about Axis, both video and network audio products, and installed quite a bit of both.  I was hoping for a budget version, as I don't think I can get the owners of the site I'm working on to spend that kind of money on this.  I've used point to point fiber solutions in the past, but my fiber runs only hit one of four points I need to cover. So I'm hoping for an affordable network solution.
This space for rent
    • COMSYSTEC
« Reply #3 on: March 25, 2021, 01:57:35 AM »
Okay. How about this:
https://www.bswusa.com/Codecs-Barix-Instreamer-P8850.aspx
Together with a decoder with amp from this list:
https://ip-audio.com/collections/exstreamer-family?gclid=EAIaIQobChMI58KAqeDK7wIVjLbICh1NagOnEAAYASAAEgKKHvD_BwE
Use it to drive regular speakers.
I don't think you will find cheaper.
-Hal
Mike Caldwell
  • Covington, Ohio
« Reply #4 on: March 28, 2021, 11:37:04 PM »
-Hal
Have you used the Barix Equipment?
I posted a message about the same equipment and did not receive any comments.
My use would be sending audio to remote location over the internet.
    • COMSYSTEC
« Reply #5 on: March 31, 2021, 08:13:31 PM »
I saw your message after I made that suggestion. I knew I heard of it someplace.  ::)
No, I haven't used it but from what I see it's easy to set up and use. And the price is right. There are many YouTube videos about setting up and using their equipment. Just Google for them if you haven't seen them already.
There doesn't seem to be anything out there that is comparable to this. There are plenty of decoders (from self contained speakers to stand alone receivers) but no encoders. I actually expected to find a software encoder app that would run on a PC but no.  It seems every decoder I found is intended to work off a SIP extension on a IP phone system.
Dunno, I have seen drawings for large projects that spec IP ceiling speakers throughout. Without any other information I would assume that it was only capable of zoned paging through the phone system with maybe background music- as much as the phone system can deliver.
So, yeah, if I had an application I wouldn't hesitate to give Barix a try.
-Hal
« Last Edit: March 31, 2021, 08:21:13 PM by Hal Bissinger/COMSYSTEC »
Lee Douglas
« Reply #6 on: April 01, 2021, 11:27:01 AM »
As always, thanks for the suggestions.  I ended up proposing the Axis equipment, as we already have experience with it.  I wonder if the Axis C8033 Audio Bridge would work as an encoder for other products?
This space for rent
Mike Caldwell
  • Covington, Ohio
« Reply #7 on: April 06, 2021, 12:14:01 AM »
Just to follow up on the Barix equipment I posted about earlier.
Yes it works!
Really easy to stream point to point over a LAN and with a couple extra
steps setting up port forwarding you can stream point to point over a
WAN / internet via HTTP.
I'm actually listening to it right now streamed from my home router with the Instreamer, set my tablet up to be a 4g hot spot, using an old Linksys router flashed with DD-WRT set up as a bridge and connected to the Exstreamer decoder.
There's a couple other ways to stream point to point over the internet but they were getting above my networking comfort zone.
For my upcoming project I think they will work and I'll keep them in mind for others.
Page created in 0.136 seconds with 24 queries.
