Author Topic: Frd, zma and ascii  (Read 1412 times)
dian r subekti
Frd, zma and ascii
« on: February 24, 2021, 11:16:38 PM »
Hi all.  Has anyone tried to create frd and zma files based on ascii in smart live version 5.4 or 7 ?.
Russell Ault
  • Edmonton, AB
Re: Frd, zma and ascii
« Reply #1 on: February 25, 2021, 03:07:14 AM »
My quick bit of Googling suggests that Smaart's ASCII format (in v8, anyway) should be roughly compatible with FRD (not sure about ZMA). You may have to comment out (with an asterisk) or remove everything above the actual data in the file, and depending on the trace you're exporting you might also need to remove a column (I don't see any mention in for FRD about about a coherence column). You'll also need to change the file extension to FRD (of course).
-Russ
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #2 on: February 25, 2021, 03:04:41 PM »
ZMA is the impedance plot, so an entirely different measurement technique.
Chris
www.grimshawaudio.com
dian r subekti
« Reply #3 on: February 26, 2021, 11:10:11 PM »
Chris
I tried to remove everything above the actual data in the file with ms excel.  and paste to notepad and save it with the extension .frd and it works.  thanks man
dian r subekti
« Reply #4 on: February 26, 2021, 11:13:24 PM »
Chris
Yes, right.  Impedance plots are different in measurement techniques.
Page created in 0.07 seconds with 24 queries.
