Author Topic: EtherCon for Cat6 cable  (Read 1462 times)
Andrew Broughton
    • Check Check One Two
« on: February 14, 2021, 05:27:39 PM »
Remind me - which EtherCons are the ones to buy for CAT6?
I remember someone saying that there was one model to avoid because they didn't mate with other "standard" (Cat5e?) EtherCons?
And which are the ones that can be installed on a cable that already has an RJ45 installed (has a split boot or some such)
-Andy
Andrew Broughton
Re: EtherCon for Cat6 cable
« Reply #1 on: February 14, 2021, 07:02:10 PM »
Is the NE8MX-B ok for CAT6? (Not CAT6a)
-Andy
Brian Bolly
  • DC/Baltimore and other Major Airports
« Reply #2 on: February 15, 2021, 08:58:07 AM »
Quote from: Andrew Broughton
Correct.  The Neutrik CAT6 version (NE8MC6-MO) will only mate with the corresponding NE8FDY-C6 panel mount connector - not with Ethercon CAT5E or Ethercon CAT6A chassis connectors.
Since that connector is for CAT6A cable/spec, it should work just fine for CAT6 as it is not a stringent a spec.  But there is a note about insulation diameter of the cable on the product page that may apply to you (or not).
Andrew Broughton
« Reply #3 on: February 15, 2021, 10:55:22 AM »
Thanks, Brian!
-Andy
James Cotton
« Reply #4 on: April 26, 2021, 06:53:21 PM »
I've use those for CAT5e too and they work fine but you definitely need to be careful of insulation diameter, had to reterminate several as they failed test immediately after being crimped and I'm sure this was down to the cores being too small. Cores should be >1.1mm diameter for these.
There is a version for smaller gauge cores (NE8MX6-T) but my Neutrik supplier doesn't list them so I've not tried them.
I'd check the diameter of your cable cores and order the correct ones.
Page created in 0.151 seconds with 24 queries.
