Author Topic: Can I use a RTS SSA324 into a clearcom  (Read 759 times)
Doug Dessero
« on: January 16, 2021, 04:25:25 pm »
I have a 4 wire wireless PL system i want to integrate into a 2 wire Clearcom system.
Will the RTS interface into the Clearcom?
« Last Edit: January 17, 2021, 01:41:05 am by Doug Dessero »
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #1 on: January 16, 2021, 05:48:48 pm »
admin
brian maddox
  • HeyYahWon! ttsss! ttsss!
Re: Can I use a RTS SSA324 into a clearcom
« Reply #2 on: January 16, 2021, 07:40:29 pm »
Which RTS Interface? Which wireless PL system? Which Clearcom system?
brian maddox
bdmaudio@gmail.com
Doug Dessero
« Reply #3 on: January 17, 2021, 01:28:54 am »
RTS SSA-324, 2 wire to 4 wire converter.
Comtek MR-182 RX,  BSA-72 (?) TX
Clearcom CLEAR-COM RM-440 PL PRO 4-CHANNEL
« Last Edit: January 17, 2021, 01:41:36 am by Doug Dessero »
brian maddox
« Reply #4 on: January 17, 2021, 09:55:42 pm »
I'm gonna go with Maybe???
That's a pretty weird kludge of bits none of which are designed to be used together, so it's certainly not gonna be plug and play. You've got odd ball connectors and pinouts and mismatched signal levels and various other issues. But I think if someone handed me those bits and gave me a day and a soldering iron [and some random connectors] I'd probably be able to get those to talk. But it ain't gonna be pretty.
brian maddox
bdmaudio@gmail.com
Doug Dessero
« Reply #5 on: January 17, 2021, 11:38:03 pm »
FYI, The Comtek has balanced XLS's into and out of the TX & RX units, RTS takes the same inputs.  My concern was whether it will interface with the Clearcom 2W which is unbalanced.   Guess I'll find out soon.  Ya, a little kludge but thats what I have to work with.
Thanks for your help.
Doug
Henry Cohen
  • Westchester Co., NY, USA
« Reply #6 on: January 18, 2021, 11:55:02 am »
The short answer is yes; this is exactly what the SSA-324 is designed to do. But you will have to spend time nulling and matching levels. Then do so again each time there is a change on the 2-wire CC side.
Connect the desired ClearCom channel to one of the System (A or B) 2-wire XLR connectors, and select Channel B on the front side selector button. Connect the four wire input and output to the corresponding System's terminal block. Best to download the SSA-324 manual
Henry Cohen
Doug Dessero
« Reply #7 on: January 18, 2021, 01:15:06 pm »
Perfect.  Thank you Henry!
Page created in 1.057 seconds with 22 queries.
