Author Topic: [solved] LUFS Live?  (Read 1785 times)
Russell Ault
  • Edmonton, AB
[solved] LUFS Live?
« on: December 10, 2020, 09:05:40 PM »
Hi all!
There's probably no simple answer, but how are people dealing with loudness and metering for live streams? My sense is that LUFS is technically something that can only really be calculated after it's already too late, so what are people using in real-time? Can something like 10EaZy be configured for estimating LUFS?
Thanks!
-Russ
« Last Edit: December 12, 2020, 12:06:08 AM by Russell Ault »
Matthias McCready
Re: LUFS Live?
« Reply #1 on: December 10, 2020, 10:35:29 PM »
Hi all!
Thanks!
-Russ
Waves has a plugin or if you a computer with a DAW post console, but pre-stream there are many options some of which are free.
If neither of those is an option I would recommend recording a sample of your content and then uploading the file here
While the last option is not "live" it will help you set your limiters and between seeing your reduction rate on the console and your loudness via the software that should help you to dial things in pre-show.
Measure twice, and cut once; this is especially important if you are a mohel.
Russell Ault
  • Edmonton, AB
Re: LUFS Live?
« Reply #2 on: December 10, 2020, 11:34:43 PM »
Waves has a plugin [...]
I was looking at that Waves plugin; it's on quite a good sale right now so perhaps I should just bite the bullet. Part of the reason I was asking about 10EaZy is that I already own a copy of it and I was wondering if I could "make do", but perhaps not.
Thanks!
-Russ
Matthias McCready
Re: LUFS Live?
« Reply #3 on: December 10, 2020, 11:46:25 PM »
Thanks!
-Russ
I am not certain that 10EaZy cannot, that is a rabbit hole worth exploring and maybe worth an email to Rational Acoustics?
That could be a feature request for the future if it is not something that can be done now?
Michael Lawrence
Re: LUFS Live?
« Reply #4 on: December 11, 2020, 01:01:00 PM »
Loudness / LUFS metering is on the list for new SPL-related features in v9. It requires a bit of replumbing under the hood having to deal with how we would handle stereo / multi-channel inputs.
But yes - it can be done in realtime, as it's basically no different than an Leq SPL measuremnet with a little bit of EQ and thresholding thrown in.
For my own work, I've been using Youlean loudness metering plugin.
https://youlean.co/youlean-loudness-meter/
 It's fantastic, very powerful, and affordable. There is a free version but I happily paid $29 for the pro license.
brian maddox
  • HeyYahWon! ttsss! ttsss!
Re: LUFS Live?
« Reply #5 on: December 11, 2020, 01:24:53 PM »
Yeah, I've been using YouLean heavily over the last 6 months or so. Highly recommend!
brian maddox
bdmaudio@gmail.com
Andrew Broughton
    • Check Check One Two
Re: LUFS Live?
« Reply #6 on: December 11, 2020, 01:58:04 PM »
How does WLM compare to YouLean, if anyone's compared the two...
-Andy
brian maddox
Re: LUFS Live?
« Reply #7 on: December 11, 2020, 02:01:42 PM »
I've not done a deep dive into either, but I've used both. The visual interface is quite different, but for me the big difference is how easily YouLean allows you to see LUfs over time with a very easy to read and understand time line. It's also a bit simpler to use as a standalone although it CAN be used as a plug in as well.
YouLean also has a free option that has plenty of features for most people.
brian maddox
bdmaudio@gmail.com
Russell Ault
  • Edmonton, AB
Re: LUFS Live?
« Reply #8 on: December 12, 2020, 12:05:44 AM »
[...] For my own work, I've been using Youlean loudness metering plugin. [...]
[...] Yeah, I've been using YouLean heavily over the last 6 months or so. Highly recommend!
Purchased (it was even on sale today!). Thanks for the recommendation!
-Russ
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
Re: LUFS Live?
« Reply #9 on: December 12, 2020, 11:10:56 AM »
I use both. I have WLM in the broadcast studio which is patched on my "safety record" console output track in Reaper. I'm multitracking and mixing for broadcast, then I patch an output of the broadcast desk back into Reaper for the safety record. WLM is set up on input FXof that track.
For Youlean, I use that when I'm mixing something in post.
I find Youlean much easier to read, and much faster to get to the proper Lufs. It has a fantastic display.
I am still using WLM simply because I have it already. It's not that it's bad, it's just not as easy to navigate or watch. Youlean has it beat on UI.
Re: LUFS Live?
Page created in 0.161 seconds with 25 queries.
