Author Topic: On the Turning Away  (Read 2121 times)
Dennis Wiggins
Re: On the Turning Away
« Reply #10 on: November 14, 2020, 01:24:40 pm »
...The solution is better powered subs.. something with real output down into the 30hz range.
Agreed.  I should be running EKXs ETXs ;) but at 71, lifting 114 lbs. is no longer an option.  The ELXs are a very manageable 73 64 lbs.
-Dennis
<edit>  Superfluous note deleted.
With regards to Paul's later comment about doorways and stairs:  The 200-18s are 20" wide.
« Last Edit: November 15, 2020, 06:19:20 pm by Dennis Wiggins »
Luke Geis
« Reply #11 on: November 15, 2020, 12:22:52 am »
I am not familiar with EV's passive stuff as much as I am their powered units. While I would love to think that I have a " sound " that keeps me employed, I find that it is really more about my ability to produce consistent, problem-free results that happen to sound acceptable to a majority of people in the room that matter. I used to own and run a LOT more passive units and one thing was easy to hear between each show. I corrected obvious problems to arrive at an acceptable sound that was dictated by the gear I had at my disposal at the time. If I was working with a Behringer PA system, it sounded like a Behringer that was running as best it could. If I had a Meyer PA and Midas Console it sounded like a Meyer PA that was running as best as I could make it. I started with a passive PA and quickly realized that powered is a conceptually better approach to a more easily obtained " sound ". I got rid on my passive system for a powered one and instantly saw why having a speaker that was tuned to the best compromise it could be at already, was a great idea. All I was required to do was fix the problems that the speaker in the room caused. Not asses if " My Sound " and the PA in the room sound was correct.
I will say this. Affordable speakers are affordable for a reason. The EV stuff is the best bang for the buck you can get. Their lower-end lines sound remarkably good for the price even, but they do have limitations. They can't give you class A performance for C grade prices. My recent PA upgrade was purchasing the JBL SRX-800 series stuff. To me, it is still the best you can get for the price. There is also no blaming the gear for the result you end up with. It is good enough that I find little if any need to spend much time tuning the PA for a sound as much as simply tuning for the sound in the room. Many of the powered systems are aiming at that same idea, make it so that there is little need to tune the PA and simply make noise and fix obvious problems.
Every speaker is inevitably going to have " A sound", but how does it sound naturally? I prefer the sound of a neutral or linear PA. To me, it sounds kind of meh. it's not too bright, not too dull, not too boomy, and not too wimpy, it just sounds realistic, and not overemphasized. It has a sound and it sounds natural, real, and even. It is not my sound at all. When I mix the band, I adjust the mic position, channel EQ, channel and bus processing, and master bus processing to acquire " My Sound ". When I'm done with the band, the master bus processing, and all other stuff go away so that the sound from the source media sounds as it was intended. I will fix what is needed if any is required.
As for DJ stuff, well I am only a DJ for those that pay me enough, but I still feel that I get more consistent and appealing results with the out of the box settings that most all powered stuff comes with. Another way to look at it is this: If the speaker sounds the way it does, it is probably because that is the best it could be made to sound and stick to the price it has. So if you don't like that sound of the speaker, then you must try another brand or model. I think as you start getting to the $700 plus point, the sound is relatively close, but is down to your flavor of how it's implemented. I.E. a $700 and $1000 speaker sound pretty close in terms of quality and output, you just have to decide what features and sound qualities of each you value more. As you get into lower-cost units, the difference in sound is more evident between similar cost units. Imagine a JBL EON vs. a QSC CP model or an EV EKX vs a Mackie SRM.
Sound is a money game. What you spend ultimately determines how good it will sound and how loud you can get doing it. If a passive speaker costs $700, it is probably going to sound better than an equivalent $700 powered unit. The problem is that you need another couple grand in amplifiers and processing to truly make that a reality. That $700 passive speaker no longer costs $700 anymore because you have almost as much more per speaker invested in other technology. Dollar for dollar powered gear sounds and performs better than most passive stuff. This assumes of course a 1:1 cost ratio. If your passive rig costs double what your powered rig does, then it is no longer an equal comparison. With a powered rig, I can turn it on and assess what I am working with. With a passive rig, I have to asses the WHOLE system to see where I can do what and with what.
Paul G. OBrien
« Reply #12 on: November 15, 2020, 10:48:39 am »
Agreed.  I should be running EKXs but at 71, lifting 114 lbs. is no longer an option.  The ELXs are a very manageable 73 lbs.
Maybe you are thinking ETX... the EKX 18sp only weighs 72lbs.
Dennis Wiggins
« Reply #13 on: November 15, 2020, 12:06:55 pm »
True!  ETX18-SP are the 114 lb. ones with significantly more range and output.
Paul G. OBrien
« Reply #14 on: November 15, 2020, 12:59:42 pm »
Each step up brings a bit more lowend extension and output but also the larger cabinet that requires, the EKX18 is right at he edge of what can be considered a 1-man lift, it's light enough but the dimensions make for a tight fit through doorways.. I have lost some knuckle skin moving mine around. The ETX18sp is a 2 man lift, the box is just too big and heavy to handle so good thing it has wheels, that doesn't help when it comes to stairs though.
Steve-White
  • Fort Worth
« Reply #15 on: January 22, 2021, 11:32:04 am »
I'll bet he's talking about BGW's 78 pound monster: https://www.dropbox.com/s/a3dhiq0l92fedy0/BGW-GTA.pdf?dl=0
I still have a few keeping my warehouse foundation from floating off into space.
Which were turds......but, everyone has their favorites.  :)
I used to work with a guy that lugged a bunch of BGW 750's around for years.  Geezus those racks were heavy, like hauling a cast iron 426 hemi to gig.  He ended up with a bunch of Carver 1.5's when they came out.  Keep a spare amp or two around and you're all set.
Saw a few club installs with BGW's in them - reliable amps they were and sounded decent.  I'd never rack one up and load it in a truck.  :)
« Last Edit: January 22, 2021, 11:34:47 am by Steve-White »
John L Nobile
« Reply #16 on: January 22, 2021, 01:04:11 pm »
That's what I used in the late 70's and 80's. Heavy, yes, but reliable and sounded great. But there weren't any light amps then that put out 200w/8 ohms a side. I did buy a Carver 1.5 but it never sounded as good on the lo end.
Steve-White
  • Fort Worth
« Reply #17 on: February 17, 2021, 08:21:11 pm »
Nothing you could pull of of the box and put into service.  But, I ran Phase Linear's for many years in club installs and portable sound.  The chassis had to be reinforced, face plates modified for rack use (the Clair Brothers amps weren't for sale yet), RCA inputs changed to 1/4", and fans installed.  I only had two amp failures in a 10 year span and it was simple output failure - still run a couple of them in my den system.  Properly setup, the PL 700 would blow the BGW 750's away.  Again, we all had our preferences.  :)
