Pages: 1 [2] 3   Go Down
Author Topic: Preferred Method for Wiring Junctions  (Read 3571 times)
Re: Preferred Method for Wiring Junctions
« Reply #10 on: October 06, 2020, 09:03:36 pm »
While these are convenient, I believe they have limitations on amperage/voltage.
https://www.wago.com/us/wire-splicing-connectors/compact-splicing-connector/p/221-415
They are, as the cool kids say, 'the bee's knees'. UL rating is 600V, 20 amperes.  IEC is 450V, 32 amperes.  Solid or stranded, fine stranded... all on the linked page.
Jonathan's comment about box fill (wire count) is worth a re-read.  Box fill (and conduit fill) is NEC 314.16.
« Reply #11 on: October 06, 2020, 10:23:03 pm »
I love the Wago connectors for being so easy to use and laying flat in a quad box. To me they seem as secure as any screw terminal.
What do you call (or part number) those hubbell boxes with the metal strain relief?
Paul Miller
« Reply #12 on: October 06, 2020, 11:48:17 pm »
The box is a Hubbell/Bell 5341-0. A matching grey steel receptacle cover is Hubbell SP82G.
The cord grips are Hubbell 3/4" NPT. The exact ones I use depends on the OD of the cord:
Carol 12/3 SJOOW - part no. SHC1034, F2, 1/2" to 5/8" cord OD, brown
Carol 12/3 SOOW - part no. SHC1037, F3, 5/8" to 3/4" cord OD, yellow
The boxes were available at Home Depot, the cord grips I think I ordered from Zoro.
Paul Miller
« Reply #13 on: October 07, 2020, 12:14:07 am »
A couple more pics of the build. Here I used Hubbell HBL5262 receptacles. At nearly $20 each, they push the price of a complete box, with a 12' cord and 6" pass-through, over $100 just in materials. People are stunned, and then insulted, when they ask me how much I would charge to build them a few.
« Last Edit: October 07, 2020, 12:18:51 am by Paul Miller »
« Reply #14 on: October 07, 2020, 12:22:50 am »
The box looks like a Bell 5333-0 or 5341-0.  The strain chuck is Raco 4802-4 or 4803-4 (I think).  Both are Hubbell companies.
Steve M Smith
  • Isle of Wight - England
« Reply #15 on: October 07, 2020, 03:05:01 am »
I've seen the wire nuts
I'm sure the rest of the world looks at american wire nuts and thinks "What???!!!".
Steve.
Jeff Lelko
  • Cape Canaveral, FL
« Reply #16 on: October 07, 2020, 04:40:39 am »
Thanks for all the input and suggestions.
In portable power distribution, movement can be more problematic than in a fixed install like a house.
I try to use connectors with screws rather than wire nuts or any kind of "push in" connector.
Those ones from HD look perfect!
That was generally my initial thought too.  I like the solid feel of the screw terminals, but also understand that they will require occasional re-tightening.  What's interesting about the Wago connectors is that they actually have a vibration spec.  I'm not really sure how that correlates to real world use, but it's reassuring to know the engineering team considered it during design.
Thanks for sharing the pictures of your project Paul!  I use the OA Windsor rubber boxes for portable power distribution, but you did an excellent job with your build as well.
I agree, and thanks Jonathan for providing all the background info.  To give some further context on my end, attached is the website picture for essentially what I'm wiring - a simple PowerCon split.  Since those use the spade terminals and not the screws like a 5-15 outlet I can't just simply daisy chain along the devices as I go.
I've learned as I researched this that apparently wire nuts aren't permissible in other parts of the world.  Interesting to say the least!
Thanks again!
Keith Broughton
  • Toronto
« Reply #17 on: October 07, 2020, 07:29:15 am »
Vibration can make a screw terminal work loose, and screws tend to not self-tighten.
Just a thought, not backed by research.
Blue Loctite is your friend for those screws that don't "self tighten"  :D
« Reply #18 on: October 07, 2020, 11:52:45 am »
That's interesting and what I was after.  The average price of the rubberized pendant boxes like Windsor uses from both Hubbell and Ericson is nearly twice the price.  I have some of the style you are using that came from an acquisition.  They have held up as well as the OA Windsor product.  Interesting.
Thanks Paul
Jonathan Johnson
« Reply #19 on: October 07, 2020, 02:42:01 pm »
Maybe a big bill, but I'd wager those boxes won't fail on you in the middle of a gig, and won't be subject to an NFG label anytime soon. Like almost anything else, you get what you pay for.
Pages: 1 [2] 3   Go Up
Page created in 0.032 seconds with 24 queries.
