Pages: 1 2 [3]   Go Down
Author Topic: EAW SB 1000e Subwoofer missing one port tubing - replacement?  (Read 1817 times)
Geert Friedhof
Re: EAW SB 1000e Subwoofer missing one port tubing - replacement?
« Reply #20 on: October 05, 2020, 08:29:56 pm »
Did you miss the video I posted that has the cabinet internal dimensions?
Are you sure the 1000Z has the same port dimensions as the 1000E?
Tim Hite
    • Bad Quail
« Reply #21 on: October 06, 2020, 12:14:25 pm »
As far as I know, the boxes are the identical, drivers are different. e uses RCF, z uses B&C and the z series was made overseas not in USA. Either way, processor settings are the same, which leads me to believe that the two versions are interchangeable.
https://www.soundpro.com/catalog/documents/83694.pdf
Bad Quail
Sound + Light
Joshua Tree, California
doug johnson2
« Reply #22 on: October 06, 2020, 01:46:24 pm »
The SB1000e and the z are the exact same cabinet with different drivers.  The e are RCF L18p300s and the z used a B&C, the model number escapes me at this time.  There were also some transition boxes that had 18sound drivers as well.
Rick Powell
« Reply #23 on: October 07, 2020, 09:07:26 am »
Somebody should be able to 3D print an exact duplicate in polycarbonate if you can get them the correct dimensions.
Mike Henderson
« Reply #24 on: October 22, 2020, 08:21:04 am »
So guys, we finally removed the woofers last night. The right side port tubing is made of cardboard and I am now understanding what about the "Inner Diameter" being 3-1/2" since the port hole itself is 3-1/2". Seems there is a lip around the port's hole to accommodate the 1/8" wall diameter and it is glued unto that lip. So now I can try to find a cardboard tubing with the dimensions since the missing left side port tube was not in the Cabinet.
Anyways, there were 2 screws missing so I will need to order those, they are hex screws.
Also, the attached is a pic of the woofer, I have written to EAW to confirm the specs of that woofer.
Matthew Knischewsky
« Reply #25 on: October 22, 2020, 12:17:50 pm »
EAW 804059 = RCF L18-P300
Mike Henderson
« Reply #26 on: October 22, 2020, 01:04:48 pm »
Yeah. This is the reply from EAW on the screws:
Quote
Hi Mike,
As I’ve said, there is no manufacturing in the USA any longer. So we are not a source for hardware.
Sincerely,
Any source to get those 2 missing screws please?
Art Welter
« Reply #27 on: October 22, 2020, 01:12:59 pm »
A hardware store.
Bring a screw along so you can match the thread.
Tim Hite
    • Bad Quail
« Reply #28 on: October 22, 2020, 07:09:16 pm »
Bad Quail
Sound + Light
Pages: 1 2 [3]   Go Up
Page created in 0.027 seconds with 23 queries.
