Author Topic: Stream Deck, TeamViewer, and QLab  (Read 1285 times)
Benjamin Krumholz
« on: August 22, 2020, 02:06:18 PM »
Anyone use a Stream Deck over team viewer? Meaning the Stream Deck is with you and you are controlling another computer connected through Team Viewer.
I have a remote rig with 2 Team Viewer Machines. One is a Control Machine running TF Editor connected to a TF Mixer. The other machine is a Playback Machine running Qlab... I would love to be able to remotely control the qlab ques using a Stream Deck or X-keys.
Using Unity Intercom to monitor audio.
Thanks
Ben
Andrew Broughton
    • Check Check One Two
Re: Stream Deck, TeamViewer, and QLab
« Reply #1 on: August 23, 2020, 01:29:15 AM »
I use n/Grok. No need for TV and works like a hot damn.
-Andy
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #2 on: August 23, 2020, 04:04:26 PM »
For those of us with poor memory skills, can you walk us through the basic mechanics of how that works?
brian maddox
bdmaudio@gmail.com
Benjamin Krumholz
« Reply #3 on: August 26, 2020, 10:11:32 PM »
So, i went out and bought a StreamDeck Mini and answered my own question.
It works pretty well so far.
At first I set up the control software on the remote computer that is running Qlab and the StreamDeck would not connect.
After that, I installed the control software on my local computer.. It connected. I mad a few buttons for simple Hotkey key strokes that Qlab has.. Go is Spacebar, Up is Up down is Down, Anything that has a Hotkey in the program you can program a key for on the StreamDeck. Then in the settings of the control software you can select a default program for the commands to be used. In this case, TeamViewer.
Boom it works! As long I am focused in to the correct software on the remote computer. The commands from the StreamDeck pass from my local computer to the remote machine.. The only problem now is that I have to run multiple TeamViewer machines at once.. I'm going to need a dedicated computer for that remote session only.. That way when i click back into my console remote session i don't go issuing key strokes for that software.
brian maddox
« Reply #4 on: August 27, 2020, 01:10:34 PM »
Fascinating. This is incredibly useful to know.
Just to be clear, you're not using Companion, you're using the native StreamDeck control software?
brian maddox
bdmaudio@gmail.com
Andrew Broughton
« Reply #5 on: August 28, 2020, 02:09:04 AM »
MUCH easier with Companion. No need for the software to be "focused" and no need for TeamViewer. If you don't want a dedicated computer just for the SD you can use an RPI. Definitely no need for TV on a local network, and optional over the internet.
It's all doable, just some steps to go through if you're doing this for the first time. I probably should make a video on how to do all this when I get some time. Too many other pressing things atm! (Sorry, Brian!)
-Andy
Page created in 0.085 seconds with 24 queries.
