Author Topic: RIO 3224 hard reset  (Read 7282 times)
Mike Cusson
RIO 3224 hard reset
« on: August 04, 2020, 01:51:10 PM »
Hello is there any ways to Hard Reset a RIO 3224 ?
Problem is : i think i put the wrong update in it!! When i check in Dante Controller i see BRLYN-II-... like i'ts not a RIO anymore!
Can someone please help?
Mike
Andrew Broughton
    • Check Check One Two
Re: RIO 3224 hard reset
« Reply #1 on: August 04, 2020, 01:57:47 PM »
-Andy
« Reply #2 on: August 05, 2020, 12:56:00 AM »
Brooklyn II is Audinate's Dante chipset.  No, you probably shouldn't be seeing that in Controller.  You should be able to reflash the firmware since you didn't brick the RIO.
Mike Cusson
« Reply #3 on: August 05, 2020, 11:29:04 AM »
Re-do the firmware update.
https://usa.yamaha.com/files/download/other_assets/6/327916/rio3224d_rio1608d_en_ug_g0.pdf
Thanks! It worked on version 3.11. Now i need to go to 5.10 for the RIO firmware and 4.08 for the Dante! Cerrect me, but i have to use R-Remote right? Will it do the Dante firmware at the same time?
Thanks again!
Mike
Andrew Broughton
« Reply #4 on: August 05, 2020, 11:40:22 AM »
Use R-Remote after v3.11. Updates both the firmware and Dante on a RIO.
https://download.yamaha.com/files/tcm:39-832167?_ga=2.193520747.794274178.1596557380-945505399.1594481001
-Andy
Mike Cusson
« Reply #5 on: August 05, 2020, 12:11:25 PM »
I see my RIO device in R-Remote but it disconnect and get stuck at 'connecting'. So i can't see the device in the firmware update section.
I use DHCP auto.
My firewall is off
All the dip switch are up on the device.
You have any ideas on that?
« Reply #6 on: August 05, 2020, 12:39:17 PM »
I use DHCP auto.
My firewall is off
Call Yamaha USA or the distributor for your country if not in the USA.  I am not certain this is a user-recoverable error.
Andrew Broughton
« Reply #7 on: August 05, 2020, 02:02:29 PM »
Good advice.
You might get somewhere with the Failsafe recovery procedure (1st doc I linked), but you might also make things worse. Best to contact Yamaha to find out what they recommend.
-Andy
Mike Cusson
« Reply #8 on: August 05, 2020, 02:47:14 PM »
Good advice.
I wrote to Yamaha.
What is weird is that i did success to put the RIO 3.11 firmware in it! Now the problem seems to be with R-Remote. And i tried with a pc and a Mac, same thing.
Nurul Aqilah
« Reply #9 on: March 05, 2024, 03:37:12 AM »
How do I reflash the firmware? This happen when my colleague was updating it.
Page created in 0.026 seconds with 23 queries.
