Author Topic: XPRS range  (Read 2811 times)
Drew Shaw
XPRS range
« on: August 03, 2020, 06:43:56 AM »
Hi everyone - id be grateful for any input re the following:
Currently mainly do this as a hobby altho i have some limited exoerience of playing on other systems
at free parties and small bars a handful of times
The music played is predominantly reggae/dub which cab bleed over to experimental/dancehall/techno so clear bass is an important factor
Due to change in circumstances i plan to upgrade n have my eye on xprs range
Budget is 6K but i want to incl a dbx 260 (is it advisable to buy this as a used item?) in price wch leaves about
5+K
So i plan fr this - 2x xprs 10"; 2x 12"; 2 x 115 sub = iv managed to source these new fr total of £4,7k brand new
which is pretty good compared to RRP
How do forum members rate this range?
There is an option of buying the xprs 215 for only £100 more expensive than a 115 - That would potentially save me
about £700 but it migtht limit my future options of running a couple of spk+sub's - the 215 can run 2 speakers each one with a dedicated sub
but why is it so cheap compared to the 115?
Also the !2s are on offer cheaperthan the 10s (150Eurios cheaper each)- does any1 have any suggestions why this could be?
Any input (incl should i considder other brands - the budget can incr a little but i dont want it going to
obscene levels - i do this for love not money and i dont want to be pushung to 8k or over) would be appreciated
Drew
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
Re: XPRS range
« Reply #1 on: August 03, 2020, 01:45:18 PM »
I would skip the DR260 and get a Venu360 instead. The 260 is showing its age and I think the 360 is easier to set up and sounds better. A used one won’t break the bank.
As far as speakers, I have never heard of any of the ones you mentioned. A question though... Why a pair of 10s and a pair of 12s?
Drew Shaw
Re: XPRS range
« Reply #2 on: August 03, 2020, 03:09:46 PM »
Well firstly since they’d b used more at hme than out and I want to hve option of placing one of 12s in a 2nd room and another in a third and I was thinking that a 12 might deal with the bass adequately enough so I dnt have to get 2 more subs...are u suggesting 2 x15 instead
The reason for the 10s is I thought that if it’s 1+1 then a 10” would be better than a 12/15 bec it’s more suited to high freq
But I dnt have the tech knowledge at the level of this forums members - that’s why I’m here
Dave Garoutte
  • San Rafael, CA
Re: XPRS range
« Reply #3 on: August 03, 2020, 03:54:56 PM »
Also never heard of XPRS.
Go with Yamaha DXR series or QSC k.2.
Those are probably as good as you can get in your price range.
Solid products with solid warranties.
Corey Scogin
  • Birmingham, AL, US
Re: XPRS range
« Reply #4 on: August 03, 2020, 03:55:12 PM »
Here are a few things to keep in mind:
- You never want the listener hearing the same audio content from two different sources. For your situation, you'd never want to set two full range speakers next to one another on one side of a "stereo" arrangement where the listener can hear two speakers reproducing the "left" side or the "right" side at the same time. It will create comb filtering effects, negatively impacting your sound quality.
- Larger speakers generally reproduce lower frequencies better than smaller speakers. The 12s should play lower. Smaller speakers can sound better for certain applications. For DJ work, I'd suggest 12s with subs. They're a good compromise of size and weight and can be used on their own if necessary.
- Different speaker models (10s vs 12s) will sound different requiring separate processing to get similar sounding results. In your multi-room scenario, this might apply. I'd recommend getting as many matching tops as you need and don't complicate it with different sized tops.
- Pioneer isn't known for professional audio. It's unlikely anyone here has heard these boxes. They might be great or they might be crap. It's hard to tell.
- Look around for similarly priced options and, if possible, go listen for yourself. I don't know what's available in your area but nearly every pro audio manufacturer builds a 12" full range powered speaker and sub. RCF, Yamaha, QSC, EV, JBL, DB Technologies, FBT, the list goes on.
- Regarding the subs, you can always add more later if you stick with the same model. Subs combine nicely as long as they are placed relatively close to each other (within a few feet).
- You shouldn't need the complexity of an external processor (DR260 or Venue360) unless doing more complicated setups such as delays. Powered boxes, when deployed as intended, are built to complement each other and have a relatively balanced sound out of the box.
Dave Garoutte
  • San Rafael, CA
Re: XPRS range
« Reply #5 on: August 03, 2020, 03:58:52 PM »
Plus if you don't get the not-so-necessary crossover, you can spend the money on better speakers.
The speaker quality will make more difference than almost anything else in your signal chain.
Mike Caldwell
  • Covington, Ohio
Re: XPRS range
« Reply #6 on: August 03, 2020, 05:06:59 PM »
The Pioneer XPRS speakers may have something going on. I looked them up and they seem to use Powersoft amp modules and have a 7 year warranty.
http://www.pioneerproaudio.com/en/sound/xprs/xprs_10.html
The external DSP would not be needed unless you wanted to use it for system EQ, zone routing, delay fills, ect.
As Rob mentioned the DBX 360 is much better and you can walk around with an iPad and make adjustments.
Paul G. OBrien
Re: XPRS range
« Reply #7 on: August 04, 2020, 07:33:22 PM »
Drew. Don't run out and buy these things just because they come from a recognized DJ brand, they don't appear to be doing anything exceptional with these boxes so they don't have any more value than a speaker from a recognized pro audio manufacturer, and less in quite a few cases.
You don't need a Driverack with these or most modern powered speakers so save your money, and pick 1 model of top and sub and buy as many as you think you will need.  In general 12's are a good compromise size.. nearly the same output and lowend extension the 15" model but substantially smaller and lighter.
Drew Shaw
Re: XPRS range
« Reply #8 on: August 05, 2020, 10:09:07 AM »
thanks for info guys - i need to go away aand give this a bit more thought
Before i do: 1) Mike - you say 'something mightbe going on with the Pioneers' What do you mean?
2) My mixer only has 2 outs (booth and master) which can only power sub +1 - i might be overlooking something simple here but how can i power 4 or 6 speakers individually w/out a management
sys
Drew Shaw
Re: XPRS range
« Reply #9 on: August 05, 2020, 10:37:19 AM »
I’m only including this link because a few members say they haven’t heard of these and those who have heard them report nothing but good things - a quick scroll down first page shows you this. However I do know that djs may not be as critical of their sound as pro audio people.
Apart from mic work (reggae can involve sme live input backd wiv dubs) I wouldn’t need them for live performance (as in real instr’s)
https://ourdjtalk.com/djchat/im-in-the-market-for-a-new-set-of-speakers.46486/
Re: XPRS range
Page created in 6.106 seconds with 23 queries.
