Author Topic: Source 4 bulbs  (Read 1051 times)
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
Re: Source 4 bulbs
« Reply #10 on: September 24, 2020, 06:34:27 pm »
Go with the 375's.
Thats a small room and they will get hot.
Don T. Williams
    • Q Systems Music & Sound
Re: Source 4 bulbs
« Reply #11 on: September 24, 2020, 07:38:22 pm »
+1 on Tim's post.  I had a client that had 20 amp circuits with commercial grade quality brand 20A breakers.  The breakers would not tolerate four 575W lamps, even though they should have.  The dimming was 4 Leviton portable 4 channel packs.  575 X 4 = 2300 watts.  20 Amps at 120V = 2400 watts, so it should work, but those breakers wouldn't last 5 minutes.  Switching to 375 watt lamps saved the day and there was a barely perceptible difference in the illumination in this situation.
Jeff Lelko
  • Cape Canaveral, FL
Re: Source 4 bulbs
« Reply #12 on: September 24, 2020, 08:23:49 pm »
I had a client that had 20 amp circuits with commercial grade quality brand 20A breakers...
Two things come to mind with this - my guess is that the inrush current is what was causing the breakers to trip much sooner than expected, and the other has to do with “continuous duty” loading on a breaker.  Best practice is not to exceed 80% of a breaker’s rated capacity if the load will be applied in a “continuous” fashion - 3+hrs if I remember correctly unless the breaker is specifically designated for full-capacity duty cycle.  More than that can cause nuisance tripping, and my guess is that a combination of these factors (high momentary inrush plus near full capacity sustained) is what caused the problem.
I saw the new LED retrofits as well.  Hopefully they’ll look good in person without any teething issues!
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
Re: Source 4 bulbs
« Reply #13 on: September 25, 2020, 12:42:17 am »
Fwiw, most breakers will work at 1x ampacity forever.
There is a curve for anything past that.
Don, I agree with Jeff it was either inrush or bad breakers.
https://download.schneider-electric.com/files?&p_enDocType=Catalog&p_File_Name=0730CT9801.pdf&p_Doc_Ref=0730CT9801
Re: Source 4 bulbs
Page created in 0.046 seconds with 20 queries.
