This case has 13 spaces of rack mount rail with a total of 26 inches of internal depth.
At the rear the rack rail is has 8 inches of clearance from the bottom of the rack, at the front
the rack rail has 4 inches of clearance from the bottom of the rack.
Above the rack rail is a sliding shelf that could be used for iPads, phone, ect. That shelf
could be removed if not needed.
When the case is opened the lower front and rear end panels lift out if you need more access
to the equipment.
External dimensions are 28 inches deep, 22 inches wide, 11 inches tall.
Overall the rack is in very clean condition, it is missing two of the rubber feet on the bottom.
$120
I can wrap it in cardboard and will ship, or we can arrange pick up in the Western Ohio area.
