Pages: 1 ... 4 5 [6] 7 8   Go Down
Author Topic: XR18 simple control surface suggestion  (Read 14955 times)
duane massey
Re: XR18 simple control surface suggestion
« Reply #50 on: May 04, 2020, 04:17:49 PM »
X-Air-Edit does not implement the MIDI fader control that X32-Edit does, so you canít just rely on X-Air-Edit. You have to use another app, like Mixing Station (see above).
No additional cords needed. Mixing Station and X-Air-Edit send all commands over Ethernet (or USB if hooked up).
Thanks. Seems rather unhelpful for it to not just plug/play with the X-series products, but it is "Behringer".
Duane Massey
Houston, Texas
duane massey
« Reply #51 on: May 04, 2020, 05:18:08 PM »
Well, damn! It seems Mixing Station will only work with Win 10. Both of my laptops have Win 7.
Duane Massey
Houston, Texas
Andrew Broughton
    • Check Check One Two
« Reply #52 on: May 04, 2020, 06:17:58 PM »
Wonít run at all on Win7? Thatís unusual.
You could set up a Win10 VM or dual boot?
-Andy
duane massey
« Reply #53 on: May 04, 2020, 06:30:11 PM »
Haven't dl yet, thought I'd see if there were any other options. Will try it tonight or tomorrow when I have the time to play with it. I know, I know, I should dump win 7, but now is not a good time.
Duane Massey
Houston, Texas
Riley Casey
« Reply #54 on: May 04, 2020, 06:38:12 PM »
Don't feel too bad. I still have an install of XP just to be able to talk to my BSS FDS366s.
« Reply #55 on: May 04, 2020, 07:36:44 PM »
I have a source of Win 10 Pro OEM licenses in Hong Kong, about $15.  You download Win 10 from Micro$oft, put it on whatever media you need, make that media bootable, and install as an upgrade.  According to a couple of online sources a valid Win 7 key will authorize the new Win 10 install just like it did when M$ was offering the 'free upgrade' over a year ago.  If it doesn't, I know this place in Hong Kong, and I've purchased both Win 10 and M$ Office keys with no problems...
"Art has always held a tenuous position between acts of subversion and status symbol collected by those who profit from the very status quo the art purports to subvert." - Stephen Colbert
Russell Ault
  • Edmonton, AB
« Reply #56 on: May 04, 2020, 07:51:00 PM »
Just to be clear, though: using an OEM license of a Microsoft product on an existing computer is a violation of the software's licensing terms (buying a license from outside your region might be as well). Whether or not this matters to you is a personal decision.
-Russ
Jon Dees
« Reply #57 on: May 04, 2020, 08:41:17 PM »
You can run a Linux VM in VirtualBox to test things out.
« Reply #58 on: May 04, 2020, 10:57:45 PM »
-Russ
I figure if it was geographically restricted the supplied key would not get activated by M$.  They have that power, ya know. ;)
« Last Edit: May 04, 2020, 10:59:55 PM by Tim McCulloch »
Andrew Broughton
« Reply #59 on: May 05, 2020, 11:04:04 AM »
Windows 10 is still free. No need to pay unless you need to change the desktop or a few other typically unimportant settings.
https://www.howtogeek.com/244678/you-dont-need-a-product-key-to-install-and-use-windows-10/
-Andy
¬ę Reply #59 on: May 05, 2020, 11:04:04 AM ¬Ľ
Pages: 1 ... 4 5 [6] 7 8   Go Up
Page created in 0.077 seconds with 25 queries.
