Author Topic: SOOW VS TYPE W Cable  (Read 1715 times)
Jeff Bankston
« on: February 06, 2020, 06:48:02 pm »
Anyone using Type W single conductor 1/0-4/0 cables from generator to power distro ?
http://wesbellwireandcable.com/SOOW/difference-between-soow-wire-and-type-w-power-cable.html
Ray Aberle
    • Kelcema Audio
Re: SOOW VS TYPE W Cable
« Reply #1 on: February 07, 2020, 09:49:32 pm »
This for cams or whatever? Well, since the NEC prohibits single pole connectors on multiple-conductor-in-one-jacket-cable, I can't imagine anyone would be using 2/5 or whatever SOOW cable for cams.
Kelcema Audio
  • Old enough to know better
  • Audio Plumber
« Reply #2 on: February 07, 2020, 10:24:43 pm »
He did say single conductor.
Jeff Bankston
« Reply #3 on: February 08, 2020, 01:45:23 am »
Single conductor "cables" not "multiconductor" cord. 4-6 "individual" 1/0-4/0 runs with camlocks.
Kevin Graf
« Reply #4 on: February 08, 2020, 08:09:57 am »
I think of cables and cords as having two or more conductors.
where as wires have one conductor.
Speedskater
Ray Aberle
    • Kelcema Audio
« Reply #5 on: February 11, 2020, 10:01:42 pm »
OK. Sorry, your thread subject said "SOOW vs Type W" so I thought maybe the discussion was "which is better, multi or single conductor?"
Kelcema Audio
Jeff Bankston
« Reply #6 on: February 12, 2020, 01:49:32 am »
Anyone used cables with W insulation and SOOW insulation ?  How has the insulation held up ? Type W is suppose to be a little tougher but I have only used W and need more cables and might go with SOOW if it holds up as good as W. A cable is single conductor , a cord is 2 or more conductors. 4/0 comes in cable and cord. I use 4/0 cable from the genny to the main distro.
« Last Edit: February 12, 2020, 01:53:10 am by Jeff Bankston »
Mark Cadwallader
  • Helena, Montana USA
« Reply #7 on: February 12, 2020, 01:57:45 pm »
At the risk of further confusion, isn't there also SC single conductor cable in sizes appropriate for feeder use?  SC is rated at 600 volts, IIRC, and is recognized for entertainment use under various NEC chapter 5xx provisions.  Is SC an option for you, Jeff?
Jonathan Johnson
« Reply #8 on: February 13, 2020, 12:46:23 pm »
Y'know, the terms cable and cord are kind of ambiguous -- they are commonly used for both multi-strand wires and multi-core wiring. Or, in the case of "cord", can refer to anything from the thread holding your shirt together to the ropes tying ships to the pier to the high-tension power lines that naturopaths freak out under.
The terms single-strand, multi-strand, single-core, and multi-core are unambiguous. They, however, roll off the tongue like a square wheel and make you sound like a freakin' pedant.
Jeff Bankston
« Reply #9 on: February 13, 2020, 06:43:25 pm »
This thread was about the durability of insulation. SOOW vs W insulation. I was asking if anyone has used both which held up better ? It was never intended to about what is a cable and what is a cord.
Page created in 0.042 seconds with 25 queries.
