Author Topic: Who makes a decent spot?  (Read 1894 times)
Kemper Watson
« on: January 08, 2020, 07:49:08 am »
 I would like to add a small spotlight to some outdoor shows. It would ideally be 120 Edison . What's out there? Thanks for your time..
Re: Who makes a decent spot?
« Reply #1 on: January 08, 2020, 01:00:50 pm »
Guess that leaves a super trooper out of the question.  I used a Chauvet Ovation that I rented once and it was decent.
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
« Reply #2 on: January 08, 2020, 06:26:06 pm »
Unless you go for the "leko on a stick" type that is getting more and more popular your only real choice is an Altman Comet. I wouldn't call it decent but it is heavy and awkward to move. The good thing is all the finger pinching and sharp edges!
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #3 on: January 08, 2020, 07:33:14 pm »
i love everything about this post....
It amazes me that after all these decades Altman STILL sells the Comet, largely unchanged from it's original.  Since they basically never die, i would think at this point we'd be overrun with them
brian maddox
bdmaudio@gmail.com
John L Nobile
« Reply #4 on: January 09, 2020, 11:09:01 am »
Had a band come through here with a Microh led 150 spot. I was quite impressed with the output and size.
Steven Cohen
« Reply #5 on: January 09, 2020, 12:20:51 pm »
You cant go wrong with a Lycian follow spot. They make small units that use 1000 watt FELs but I would recommend an arc based light if your budget and need permits.
http://www.lycian.com/index.html
Craig Hauber
« Reply #6 on: January 12, 2020, 10:32:01 pm »
Ultra Quartz by Strong (used to be a Lycian product)
or the basic Strong Touperette -there has to be a million of those things used around the country.
Many of the small ones I've encountered lately don't have the zoom focusing capability and you end up having to use the iris to set your spot size.  Unfortunately the farther you get back, the larger the native spot diameter and you have to iris down even more.  The end result is a very dim spot at distances and a burnt iris if used this way for a long time.
I am astounded at how many of the small "mini" or compact followspots are plagued with this issue and you are way better off with the source-four at this size level.
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Jeff Lelko
  • Cape Canaveral, FL
« Reply #7 on: January 12, 2020, 11:22:14 pm »
I tend to agree with this.  Between all the different flavors of Source 4s and their accessories, itís hard to top this until you step up to the much larger units.  I recall using an HMI 575w followspot that ran on 120 probably 10 years ago, but I canít remember the make or model (maybe an Altman Satellite).  I just remember that it had an external ballast and was anything but portable.  Elation is also offering a followspot with the 15R lamp that runs on 120, but I have yet to see or use one.  Good luck!
Craig Hauber
« Reply #8 on: January 13, 2020, 07:07:30 pm »
I just looked a bit closer at the strong lighting website.
http://strong.lighting/followspot/
The have a couple arc-sourced models that fit easily on a 15A circuit.
As well as having a couple LED models now -I'm definitely liking that idea, low heat, long life and minimal power draw!
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Robert Healey
« Reply #9 on: January 15, 2020, 03:11:25 pm »
I looked at a bunch of follow spots at LDI this year. In the 40'-120' throw range LED is taking over so there are a lot more 120V/20A options than before. In LEDs, Strong and Lycian both looked very nice in the mid-price range. Altman and Chauvet have LED spots in the lower-price range. Robert Juliat is the king but you'll pay for it.
¬ę Reply #9 on: January 15, 2020, 03:11:25 pm ¬Ľ
Page created in 0.045 seconds with 25 queries.
