Author Topic: Tone Bursts and Open Circuit Voltage to Measure Excursion  (Read 2343 times)
Frank Koenig
« on: December 09, 2019, 05:42:52 pm »
Splitting this off from "Lab Lounge -- Distortion in Front Loaded Subs". I tried a simple experiment which quickly revealed a gap in my reasoning, although I still have some hope for the general approach.
The trouble is that when I (asynchronously) open the circuit from the amplifier output to the speaker, the resulting step, being broad-band, excites the natural frequencies of the system. This results in a kind of step response superimposed on the desired exponentially decaying sine wave envelope, which seriously confounds the measurement. In the example below the speaker was excited at about 10 V rms at 100 and 60Hz. The scope was triggered off the switch drive which was not synchronized with the sine wave. I put the scope into infinite persistence mode so as to generate an envelope as the speaker's voltage waveform "crawled" across the screen. Clearly, these are anything but exponential decays.
Simply windowing the tone-burst prior to the switch opening, while narrowing the bandwidth, will damp the motion of the speaker as long as it's still driven from a voltage source. Perhaps a smooth increase in the source resistance, a sort of "source impedance window" would have the desired effect. The question is, does there exist a window that will not excessively damp the system while not excessively exciting it with out-of-band energy?
I seriously doubt I'm the first to try to go down this rabbit hole, and not sure I'll pursue it further at this point. Thanks for indulging me and ideas are welcome.
--Frank
I used other frequencies, too, but can't get the forum to swallow the images. I'll post separately if anyone wants. -F
« Last Edit: December 09, 2019, 05:53:01 pm by Frank Koenig »
Re: Tone Bursts and Open Circuit Voltage to Measure Excursion
« Reply #1 on: December 09, 2019, 06:12:41 pm »
sounds like you have too much time on your hands...
Frank Koenig
« Reply #2 on: December 09, 2019, 06:28:14 pm »
Touché! But I might not be alone  :)
« Reply #3 on: December 09, 2019, 06:51:39 pm »
that was just easier than answering your question.. (as if I know the answer).
Lots of moving parts in there.
Mark Wilkinson
« Reply #4 on: December 11, 2019, 11:07:08 am »
Frank, I really wish I could chime in but honestly I have a very hard time even understating what you're trying to do.
What I'd give for some formal engineering/academic training sometimes.  Sorry, it's not fair....you're always helping...me is always digging to understand.
Anyway, are you trying to measure the decay of the driver by reading its voltage after both a drive signal and connection to the amplifier is removed?
Kinda sounds like it, but that doesn't make a lot of sense not to have amp damping in place...so I guess I'm missing things.
Missing ….like whatever your after, what is the purpose as opposed to say a set of harmonic measurement sweeps with REW?
« Reply #5 on: December 11, 2019, 11:33:48 am »
--Frank
I too am a little confused about what you are asking...
I was introduced to step functions(?) back in the 70s a technician... we were splicing together pitch shifted audio samples and hard blanking or muting to 0V between samples could cause unexpected perturbations. The energy introduced could be larger if there was DC immediately before or after the blanked segment. You might reduce the energy introduced into your speaker by coordinating the disconnect with zero crossings, but if you have ever listened to tone bursts there is still audio perturbations related to the on/off step function even if started and stopped at zero crossings. Also with tone bursts you want to present even number of cycles otherwise you will introduce a DC component from the odd half cycle.
In addition driving and then disconnecting an amp from a speaker, while in motion, will turn that speaker motor into a microphone of sorts generating voltage output related to the continued motion.
I doubt this answers your question, but some stuff to chew on...
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #6 on: December 11, 2019, 01:26:23 pm »
It's an odd one. I feel like, having a Physics background, I ought to be able to make a reasonable go of this.
So.
Let's consider the free-air driver case for starters.
If you excite it at a fixed frequency, there are three possible places you can "let go" of the driver:
- Maximum displacement, zero velocity
- 0 displacement, maximum velocity
- Some displacement and some velocity. Okay, that's many places.
Bear in mind that, at low frequencies, loudspeakers are a damped spring-mass system. When connected to an amplifier, Qts is low, ~0.3. Disconnected, Qts = Qms, which tends to be high, ~10.
ie, there'll be ringing when disconnected. That's according to Frank's plan.
We're going to assume there's no hysteresis of any kind. ie, what happens to the cone is a function of the usual equations of motion. That assumption does usually hold, more or less. I've heard of cases where it might not be true, but the effects are fairly small so we can put that to one side for now. If someone would like to go into that, I'd be interested.
Let's consider the three cases I've outlined above:
- With maximum displacement and zero velocity, the driver will ring at Fs. That should be obvious - think about a pendulum.
- With maximum velocity and zero displacement, you've effectively given the cone a "kick". It has kinetic energy. My bet would be that over the time of a cycle or two, the output frequency will shift to Fs and then the energy will dissipate.
When it comes to damped oscillators, I like to imagine a pendulum in custard. If you gave the pendulum a really hard kick, it'll set off quickly but then tend towards its natural resonance. Probably as it reaches the excursion maximum.
The third case is just a convolution of the above cases - it'll set off quickly, from a non-zero displacement. So long as the speaker it within it's linear region, I don't think there's any additional complexity to consider.
Now, let's slap that driver into a ported cabinet. Sealed cabinets are trivial - the spring of the air inside the cabinet contributes to that of the suspension, and nothing really changes from the above.
So. Ported cabinets.
Simple enough: you've got a mass (slug of air in the port) and a spring (compliance of air in the cabinet).
... Which is all being excited by another mass (cone) that's on another spring (suspension) which mostly combines with the first spring (air).
At this point, it's complicated.
However, we have a secret weapon: impedance curves.
Having thought a while, I'm convinced that the "let go" output will simply tend towards that of the speaker being driven by a high impedance. For a ported box, there are two impedance peaks. One's below the port tuning, and one's above.
I suspect that what would happen when you "let go" of the cone is that the output will head towards those two frequencies.
On the 'scope, I'd expect to see them modulating each other. It kind-of looks like that on the screen captures, but it's difficult to tell for sure.
The TL;DR is that I'm not convinced that watching a speaker after it's been disconnected will tell you much information about the previous excursion state.
Chris
www.grimshawaudio.com
Frank Koenig
« Reply #7 on: December 11, 2019, 10:21:45 pm »
So.
Chris
Chris, I appreciate your detailed reply. Thanks. You understand what I was trying to do and why it doesn't work, at least in this form. I was reaching way back to my days of motor speed controllers that use the motor's own back EMF as the tachometer. Speakers and permanent-magnet (or shunt-wound) DC motors have a lot in common but they are not the same.
I've been looking at input impedance as a way of getting to excursion but the model is not so simple, requiring values of parameters that we'd rather not have to know a priori. This might be what the better powered speaker manufacturers do for their excursion limiters. I think what folks here would like is a fairly direct way to measure excursion that can be used as a post-design check and for DIY side chain filter equipped peak limiter settings.
Here's an article from the good folks at TI about one approach. They're concerned with fingernail-size phone speakers but the physical model looks to me as though it would apply to 21 in. subs as well.
http://www.ti.com/lit/an/slaa857/slaa857.pdf
All for now. Guess I better stew awhile and save up for that interferometer  ::)
--Frank
« Reply #8 on: December 12, 2019, 12:07:32 am »
--Frank
Please excuse my simplicity but isn't the position sensor on servo drivers such as the Infinity Watkins woofers what you are after?
Also Apogee amps needed a sense lead right next to the voice coil.  I know they were doing more than measuring voltage like the old Meyer processors.  I am going to take a look and see what the Apogee circuit was doing or I am sure somebody will come along that knows.
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #9 on: December 12, 2019, 09:11:17 am »
--Frank
I would be interesting in knowing what powered speakers might be doing this.   In my experience people really give powered speakers a lot of credit for doing things they really don't.
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Page created in 0.051 seconds with 23 queries.
