Author Topic: Type SJ cable news  (Read 1276 times)
John Fruits
Type SJ cable news
« on: December 07, 2019, 05:52:56 pm »
Steve Terry posted this at CB.
https://www.controlbooth.com/threads/new-rules-for-type-sj-in-2020-nec.46479/
It looks like it still doesn't allow Type SJ for on deck stringers.
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
frank kayser
Re: Type SJ cable news
« Reply #1 on: December 08, 2019, 05:02:01 pm »
No, but a slight relaxation for other uses.  Thank's for the heads up.
frank
Brian Jojade
« Reply #2 on: December 12, 2019, 04:15:32 pm »
"or installed in a location that inherently prevents physical damage to the cord."
Sort of vague in the description.  As long as you can come up with an argument that can say the way you installed the cord inherently prevents physical damage, you might be able to convince an inspector that it's A OK.  If they disagree, however, then you'll have to re-run heavier cords.   Eg, if you run your stringer along the very edge of the front of the stage, you may be able to say that since nobody will be nearby, it's inherently protected.  An inspector may counter that it's still possible to damage the cord if something slides off the edge of the stage.
Brian Jojade
Tim Hite
    • Bad Quail
« Reply #3 on: December 12, 2019, 06:53:03 pm »
Read the new regulation. Sure looks like it's intended for stuff that will be flown and SJ must be covered when on the deck.
Bad Quail
Sound + Light
Joshua Tree, California
Page created in 0.03 seconds with 21 queries.
