Author Topic: ULXD4Q, cascading 3 units  (Read 588 times)
Brian Adams
    • Adams Production Services
« on: November 06, 2019, 09:37:37 am »
I normally use a UA844 to distribute my antennas, but I have a rental going out this week (local high school theatre), and I need to squeeze 3 receivers into a 4 space rack. This means I'll have just enough room in there for either a Furman or a distro, but not both. I'd like to have the Furman in the rack to manage the power and keep things looking clean, but this would mean I'd have to cascade all 3 ULXD units. I know this is theoretically possible, and people have done it, but I've never cascaded more than the recommended 2 units. What are the real-world negative implications of cascading 3 units, and are the disadvantages great enough that I should avoid doing this?
Brian Adams
Vermillion, SD
adamsproductionservices.com
Scott Helmke
Re: ULXD4Q, cascading 3 units
« Reply #1 on: November 06, 2019, 09:53:48 am »
Are they all the same frequency band?  Generally the cascade outs are band-limited.
Brian Adams
« Reply #2 on: November 06, 2019, 10:24:08 am »
Yes, all of my ULXD is G50 band.
Brian Adams
Vermillion, SD
Aram Piligian
« Reply #3 on: November 06, 2019, 12:19:07 pm »
I haven't noticed any significant ill effects in real-world use. If I were in a tough RF environment I might think twice, but for average uses with good antenna placement and SNR it seems fine.
Brian Adams
« Reply #4 on: November 06, 2019, 02:26:36 pm »
Thank you, Aram. This is exactly what I wanted to hear. I'd say this is an average environment, but I'll definitely be cautious in more challenging spaces. Thanks again!
Brian Adams
Vermillion, SD
Luke Geis
« Reply #5 on: November 07, 2019, 09:04:08 am »
The literature says 2 units, but it also says you can do more if you don't mind potential issues.
Per Shure's website:
Note: The RF cascade ports continue to operate if more than two units are cascaded.  However, the issue is RF signal degradation (IMD and RF noise)that will occur each time the signal passes through an RF cascade circuit.  At some point, the RF signal will become too distorted/corrupted to be useful.  Thus, Shure recommends the conservative approach to cascade only two units.  No damage will occur if more than two units are connected in cascade.
Bob Charest
  • Lab Lounge
  • Westbrook ME, USA
    • Bob Charest Band
« Reply #6 on: November 07, 2019, 09:32:21 am »
I need to squeeze 3 receivers into a 4 space rack...
Hi Brian,
We used to have 12 channels of ULXD as well. We cascaded the 1st two into one set of the front-mounted 1/2 wave antennas and let the 3rd unit use its own set.
On the smaller stages that we would play on (24'-36' x 12'-16') wee had excellent coverage just using the front-mounted 1/2 wave antennas.
Best regards,
Bob Charest
Scott Helmke
« Reply #7 on: November 07, 2019, 10:38:41 am »
If you really want to squeeze out as much performance as possible, cascade the A and B antenna chains differently.
Something like antenna A starts in receiver 1, then 2, then 3, but antenna B starts in receiver 3, then 2, then 1.
Keith Broughton
  • Toronto
« Reply #8 on: November 07, 2019, 11:50:22 am »
I spoke with a Shure tech a while back, and he said a cascade of 3 is workable.
One suggestion I read was to use the middle frequencies on the 3rd unit, rather than ones at the high and low end.
Jason Glass
    • CleanWirelessAudio.com
« Reply #9 on: November 07, 2019, 03:09:18 pm »
An excellent tip!
Page created in 0.088 seconds with 24 queries.
