Pages: 1 2 [3]   Go Down
Author Topic: Behringer NX4-6000 reliability?  (Read 2797 times)
Art Welter
Re: Behringer NX4-6000 reliability?
« Reply #20 on: November 15, 2019, 02:32:21 pm »
Chris,
Thanks for the test!
For what it's worth, when testing the NU4-6000 with two bridged mono pairs each driving four ohm loads just below the illumination of the clip/limit light each put out 85.5 volts at 60 Hz. The mains voltage on a 100' 10AWG 120V line dropped from 118.1 volts down to 107.2 volts, drawing 31 amperes. If the power supply was a full 120 volts, output would probably be around 96 volts bridged mono.
Using just one bridged mono pair, the amp ran for 40+ seconds before I terminated the test, as the amp was drawing 19.8 amperes, and the "tired" 20 amp mains breaker had popped several times in various tests already.
Art
Dennis Wiggins
« Reply #21 on: November 17, 2019, 04:12:19 pm »
...I went 10dB into clip and found the same results.
- Left to their own devices, the level seems to stay constant for at least 10 seconds.
I did plenty of "no load" testing to determine structure. I trimmed pink noise to be at Unity at main outs and on the channel strip. I typically run program between -20 and -10 w/extreme peaks at 0. This is the max I design for, leaving plenty of room for "screw-ups." The VSX is set to start limiting at +9,  2.5:1.
The self-noise (a slight, noticeable "hiss") of the VSX26, which outputs directly to the amp channels, triggers the NX4's "signal" LED right at "3 O'clock." This is normal (edit: for a VSX). I backed off one click.
I always back off the amp inputs to "noon" at the beginning of a show and advance, as necessary, as the gig progresses. This is specifically why I needed 4 amp channel controls at my fingertips. I like my mixer to be the same all the way through a show.
With the output I am hearing (albeit, indoors), I doubt that I'll get near the B's limiters, except when I add Kosmos effect which will easily cause the sub channels to hit the B's limits (it does the same with the IPR3000). As always a little of that goes a long way.
It's raining. Bummer. I want to crank it up all the way.
Thanks to All!
« Last Edit: November 18, 2019, 06:09:13 pm by Dennis Wiggins »
Art Welter
« Reply #22 on: November 18, 2019, 04:02:57 pm »
The self-noise (a slight, noticeable "hiss") of the VSX26, which outputs directly to the amp channels, triggers the NX4's "signal" LED right at "3 O'clock." This is normal. I backed off one click.
Dennis,
The change in meter ballistics between the NU4 and NX4 is funny, Behringer got it wrong on both-
NU4 uses -24, 12,-6, limit, the NX4 is -40, -6, -3, limit. Who cares about -40 dB, less than 1/10th of a watt at 4 ohms?
That said, I still wouldn't consider a 40 dB signal to noise ratio "normal" for this century, but we all get used to different stuff  ;).
Art
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #23 on: November 18, 2019, 05:33:45 pm »
Yeah, the NX series effectively have meters that jump from "I'm doing almost nothing" to "I'm in the last few dB of headroom". Nothing in-between.
The NU series got the LEDs better in that regard.
Chris
www.grimshawaudio.com
Dennis Wiggins
« Reply #24 on: November 18, 2019, 06:06:38 pm »
...the NX4 is -40, -6, -3, limit. Who cares about -40 dB, less than 1/10th of a watt at 4 ohms?
For Ceremony to Dinner Music to Dance Hall -40 to -6 is exactly the "guard rails" I run between on my mixer. Pure dumb luck, I guess.
-D
« Last Edit: November 18, 2019, 06:11:15 pm by Dennis Wiggins »
Pages: 1 2 [3]   Go Up
Page created in 0.059 seconds with 20 queries.
