Pages: [1] 2 3   Go Down
Author Topic: Behringer NX4-6000 reliability?  (Read 2234 times)
Dennis Wiggins
« on: October 21, 2019, 05:22:21 pm »
Has anyone had any bad experiences (reliability, early limiting (pumping), intermittent shutting down) with the Behringer NX4-6000? The online reviews are very scarce.
I am only needing 400-500 WRMS @ 8Ohms x 4. All channels will be high-passed BW24 @35Hz, or higher, and will never be running 2 Ohm loads.
It would only be used 3-4 times per year, so I am not willing to make a higher investment as I am accomplishing the same thing now with a pair of original (silver) IPR3000s. They are just right for my purposes.
I would just want to "shrink the rig" a bit.
Len Zenith Jr
Re: Behringer NX4-6000 reliability?
« Reply #1 on: October 21, 2019, 05:40:08 pm »
That amp only puts out ~48 volts continuous / channel so about 276 w into 8 ohms which is about 2 dB's lower than you had hoped for. The IPR3000's are closer to 58 volts / channel continuous.
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
« Reply #2 on: October 21, 2019, 05:53:33 pm »
I have 3, bought from a forum member.
The 48v is a hard limit. It has no oomph beyond 48v.
That said... bridge a pair and it does quite well into an 18" sub.
No issues with the amps so far, all measure very well.
Dennis Wiggins
« Reply #3 on: October 21, 2019, 06:02:21 pm »
Hmm... In reality then,  I can probably expect about 250@8, 500@4, and about 1000@2. That's a long way from 6000(!), but may do for lower volume (dinner music and talking-head) gigs.
 My socks are still on, and my head has no room. ;)
There will typically be 4 Sb122s (2/channel) and 2-Sx300s (1/channel).
I also do a lot of mix and match with Peavey Impulse100/1012, DXR10/12 and EV ZXa1-Sub, EV ZXa1 and ZX1 cabs. This is just another tool.
« Last Edit: October 21, 2019, 06:25:06 pm by Dennis Wiggins »
Dennis Wiggins
« Reply #4 on: October 21, 2019, 06:23:50 pm »
...The 48v is a hard limit. It has no oomph beyond 48v...
Does it, at least, limit gracefully, or does it "pump"?
As you you can tell, I'm a bit wary... I am comfortable with the the "feel" * of the IPR 3000s, but would probably find the NX4 a bit "squishy."
* I am a DJ, and hitting the limiters is what I listen for - been doin' it since '78 - I ain't gonna change.
It's kind of like when you twist the grip and hit the power band. You let up.
Unless you don't. That's when the limiters save you ;D
(Specifically, I have my VXS26s set to 'knee' at the same level that DDT would kick in on the IPRs. It's pretty idiot-proof; the idiot being me.)
« Last Edit: October 21, 2019, 07:47:17 pm by Dennis Wiggins »
Len Zenith Jr
« Reply #5 on: October 21, 2019, 09:25:28 pm »
Going from two IPR3000's to one nx4-6000 saves you a whopping 1.6 lbs! I think you've reached the point of diminishing returns.
DDT circuitry is about as graceful as a limiter as you are going to get built into an amplifier. There is no knee on the nx4-6000, it just flatlines at 48 volts, however you could set up your DSP to ease into your desired limit.
Dennis Wiggins
« Reply #6 on: October 22, 2019, 12:19:29 pm »
That finishes it off, as it coincides with what Nathan also said about about how it acts when "hitting the rail".
Thanks to All. End of story.
« Last Edit: November 05, 2019, 10:22:17 am by Dennis Wiggins »
Art Welter
« Reply #7 on: October 24, 2019, 10:49:31 am »
Nathan,
The NX4-6000 are a fairly recent addition to the Behringer line, notice any differences between them and the three NU4-6000 I sold you?
Art
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #8 on: October 24, 2019, 01:40:13 pm »
... and halved your rack size.
I have a couple of NX4-6000s. One ran monitors (replaced with a Powersoft T304) and the other lived with a DCX2496 for smaller events. Both did fine. The monitor amp had an easy life at 8ohm/ch, but the one being used for smaller events would often run with Ch1 & 2 driving 8ohm/ch, and then Ch3/4 bridged into a pair of subs.
Both have always done the job for me, and never sounded bad. The Powersoft T-series sounds better, but with that price difference it's to be expected.
Chris
www.grimshawaudio.com
Nathan Riddle
  • Niceville, FL
« Reply #9 on: October 28, 2019, 08:55:12 am »
Nathan,
Art
Awe man, you nicely told me I was wrong! What a great guy!
So yeah, Dennis, what I posted was about the older model NU4 NOT the new NX4 you asked about.
Sorry. Thanks Art.
Pages: [1] 2 3   Go Up
Page created in 0.045 seconds with 25 queries.
