Author Topic: Gobo Holder  (Read 541 times)
Jamin Lynch
  • Corpus Christi, TX.
Gobo Holder
« on: September 26, 2019, 05:30:50 PM »
I somehow lost the gobo holder for a Chauvet EVE-E-100Z Leko. Anybody have an idea for holding a gobo in place to get me through an event for one night?
Thanks
MAGA-Make Audio Great Again
Mark Cadwallader
  • Helena, Montana USA
Re: Gobo Holder
« Reply #1 on: September 26, 2019, 06:33:19 PM »
Assuming you don't have a roll of "black wrap" on hand, I would try as a last-ditch effort to use heavy aluminum foil (pie pan or roaster pan material) and cobble something together.   The aluminum is heat resistant, easily formed, and can be folded back on itself as needed for approximating the correct thickness.  Best of luck.
Brian Jojade
Re: Gobo Holder
« Reply #2 on: September 26, 2019, 07:09:41 PM »
+1 on making one out of tinfoil.  Since you're dealing with an LED fixture instead of a conventional fixture, the heat issue should be minimal.  You may have to experiment a little to get the shape and position of the gobo just right, but it shouldn't be too tricky.
Brian Jojade
Re: Gobo Holder
Page created in 0.032 seconds with 24 queries.
