Author Topic: Acoustic Shadowing: Unpacking Wave Numbers (k) & Introducing Wave Ratio Thesis  (Read 3168 times)
M. Erik Matlock
  • Global Moderator
  • Senior Editor Live Sound International/ProSoundWeb
    • M. Erik Matlock on PSW
Acoustic Shadowing: Unpacking Wave Numbers (k) & Introducing The Wave Ratio Thesis
If youre truly interested in learning about sound propagation and architectural acoustics, its something you should be acquainted with, at least casually.
By Michael Fay September 9, 2019
OK, I get it. This topic may be too esoteric for many, but if youre truly interested in learning all you can about sound propagation and architectural acoustics, its something you should be acquainted with, at least casually.
Im going to give you the final answer right up front. Its either: A: 11.00, B: 0.84, C: 7.50, or D: none of the above.
The question: When dealing with obstructions, which of these physical dimensions does not present meaningful acoustic shadowing in the upper speech range of audio? The answer is B: 0.84.
But why, and how is this information unpacked and calculated?
Continue reading here: https://www.prosoundweb.com/channels/study_hall/acoustic-shadowing-unpacking-wave-numbers-k-introducing-the-wave-ratio-thesis/
Train the next generation. Success without a successor is ultimately failure. wywu.org
Page created in 0.03 seconds with 19 queries.
