Author Topic: PSM1000 frequency ranges  (Read 794 times)
Andrew Broughton
    • Check Check One Two
« on: August 15, 2019, 03:46:14 pm »
So... Why has Shure left out ch 26/27 in their available frequency ranges for the PSM1000? (NA)
-Andy
Henry Cohen
  • Westchester Co., NY, USA
Re: PSM1000 frequency ranges
« Reply #1 on: August 15, 2019, 05:05:36 pm »
Presuming you're referring to the G10 band, the tuning range is 470-542 MHz. TV channel 26 is 542-548, channel 27 is 548-554. 72MHz is likely the widest tuning range they can go while meeting FCC technical specifications and/or staying within component tolerances when operating at 100mW.
Henry Cohen
Andrew Broughton
« Reply #2 on: August 15, 2019, 05:50:39 pm »
Thank you, Henry.
Yes, G10 and J8A are the only 2 frequency ranges the PSM1000 ships with in the USA. Ch 26/27 542-554Mhz is not part of their ranges.
Shure says it's because their product's range is "only" 72Mhz. and picked the missing range arbitrarily.
I wonder if the 100mW limitation is the reason the (full-spectrum/138Mhz range) Lectro Duet maxes out at 50mW?
-Andy
Henry Cohen
« Reply #3 on: August 15, 2019, 06:14:05 pm »
I'm fairly certain only the G10 and X1 bands are now available as both J8 & L8 can tune to the re-allocated spectrum: OEM's had to cease sales in the US of equipment that could tune to those auctioned bands in Oct 2018.
Quote
The 138MHz tuning range is simply the contiguous bandwidth of the re-allocated UHF spectrum; 470-608. To add the additional 2MHz at 614-616 at restricted power was likely more trouble to Lectro than it was worth. (Karl?)  Let's also remember the Duet is newer technology and design by at least 10 years.
But in general RF power output and operational bandwidth [as a percentage of tuning range] are inversely related.
Henry Cohen
Jason Glass
    • CleanWirelessAudio.com
« Reply #4 on: August 15, 2019, 06:35:40 pm »
J8A and L8A bands are firmware-upgraded (downgraded; let's be honest) bands.  J8A tunes up to 608 MHz.   L8A covers the cellular band 71 duplex gap @ 10mW max TX power.  I had 6 channels of L8A out this weekend in Anaheim and they saved my hide.  10 mW was more than enough power for A level international acts on an 80x60 ft. performance area.
Andrew Broughton
« Reply #5 on: August 16, 2019, 11:52:45 am »
So then...
Is it possible that the PSM1000 could have had been able to tune to the full legal spectrum ala the Duet and Axient, or is there some electrical/physical reason why that wouldn't be possible? Will there be an "Axient" version of the PSM1000 that can tune the full spectrum does anyone think?
Are PSM1000 systems that run in the X1 band available/legal in NA?
-Andy
Henry Cohen
« Reply #6 on: August 16, 2019, 12:05:47 pm »
Thank you for the clarification.
Henry Cohen
Henry Cohen
« Reply #7 on: August 16, 2019, 12:11:01 pm »
Depends on the bandsplit and firmware of the unit(s) in question.
Quote
Given the market, spectrum changes and Shure's business acumen, I can't imagine Shure not working on the next generation of PSM as we speak . . .
Quote
Yes, but a Part 74 license is required to legally operate in the 941-960 MHz band.
Henry Cohen
Steve Litscher
    • 608 Sound and Light
« Reply #8 on: August 16, 2019, 04:07:52 pm »
Minor tangent, but related to PSM1000....
What are you guys using for antennas? I'll be heading out on a tour that includes small-to-moderate theaters (1500 seats), and will have the PSM1000 rig just off of stage right. Any need for fins or a helical?
Henry Cohen
« Reply #9 on: August 16, 2019, 04:34:14 pm »
It's always best practice and prudent to use an appropriate dipole based omni or directional antenna (based on coverage requirements relative to antenna position) up high to get over obstructions (human and non-human alike), and to use a low loss (double shielded) coax of the largest diameter / shortest length manageable.
Generally, a circular polarized antenna is a very good choice in order to mitigate polarization mismatch as the performer moves about.
Remember that the receiver section in an IEM pack is not nearly as selective or high Q as a rack mount mic receiver, given its very limited physical size requirements, and it's crucial to achieve the maximum CNR possible at the receiver, without overloading it. That's only possible with a gain antenna above (or below) all obstructions and in appropriate free field.
Henry Cohen
Page created in 0.071 seconds with 22 queries.
