Author Topic: Dante with Ubiquiti Network  (Read 1145 times)
Jake Abramson
« on: August 07, 2019, 10:39:10 pm »
Had an existing basic Dante network with 3 devices running on a dumb switch. Wanted to move to Unifi hardware. Devices are passing audio properly on Unifi network, however I cannot get the Dante device discovery/configuration tool to work when connected to Unifi hardware. Plugging devices into computer directly show properly, and when all connected to dumb switch. I can ping the devices when connected to the network.
Steps taken:
Set up basic VLAN with only Dante Devices (and computer to configure)
All devices on same switch (UniFi Switch 8 POE-150W)
Network VLAN Configuration:
Network VLAN Only
IGMP Snooping Disabled
DHCP Guarding Disabled
Operation   Switching
Link Negotiation   Auto
Storm Control   Disabled
LLDP MED   Enabled
802.1X Control Force Authorization
Port Isolation Disabled
Storm Control (all) Disabled
Rate Limit Disabled
Even tried moving to main LAN and still no difference.
Strange part is that the audio is still passing properly between the devices. Just seems that the device discovery is being blocked somewhere.
Note in the Dante Network Configuration related to device discovery.
"mDNS and DNS‐SD for discovery and enumeration of other Dante devices (including Dante Controller and Dante Virtual Soundcard) is on 224.0.0.251:5353. o AES67 discovery is on 239.255.255.255: 9875"
Looking in wireshark, I see the on 224.0.1.129 broadcasting from the dante devices.
Any ideas?
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #1 on: August 07, 2019, 10:44:19 pm »
Any ideas?
admin
Andrew Hollis
Re: Dante with Ubiquiti Network
« Reply #2 on: August 16, 2019, 09:32:49 am »
Discovery is multicast. Your switch is blocking multicast mDNS. Enable mDNS (most switches do by default).
https://www.audinate.com/sites/default/files/PDF/adding-dante-to-your-network-audinate.pdf
Page created in 0.055 seconds with 24 queries.
