Author Topic: Sennheisers "GZL 5000" "same as" RG-213?  (Read 2148 times)
Miguel Dahl
Re: Sennheisers "GZL 5000" "same as" RG-213?
« Reply #10 on: February 03, 2020, 12:46:30 pm »
Can I bump this? What happens if I'd use a 75Ohm barrel instead of a 50?
« Last Edit: February 03, 2020, 12:58:11 pm by Miguel Dahl »
Henry Cohen
  • Westchester Co., NY, USA
« Reply #11 on: February 03, 2020, 01:41:18 pm »
Presuming this is for a receive application and you use the current spec 75 ohm adapters (where the pins/jacks are the same size as 50 ohm connectors), all will be good; there'll be no losses of any significance.
Henry Cohen
Miguel Dahl
« Reply #12 on: February 03, 2020, 02:14:24 pm »
It's indeed for receive. Thanks. I was under the impression that it's a close to very bad thing to use, even though I've used them on many occasions without hiccups.
Ike Zimbel
    • Zimbel Audio Productions
« Reply #13 on: February 03, 2020, 03:12:20 pm »
So if the GZL cable is LMR-240-ish then I'd be good with one booster for 60 meters of the Ecoflex cable. I guess if I join two cables to get the 60 meters with a BNC male-male the drop would be negligible?
Hey Miguel, I'm late to the party on this thread, but I'm curious about what actual cable lengths you are using. I noticed that you gave all specs in meters, but most of the replies from this side of the pond were in feet. Are you really running 60-100 meter antenna runs? 60m is 196', 100m is 328'. Both are really, really long cable runs.
~Ike Zimbel~
Wireless frequency coordination specialist and educator.
Pro Audio equipment repair and upgrades.
~416-720-0887~
Miguel Dahl
« Reply #14 on: February 03, 2020, 04:07:17 pm »
This is an "old" thread regarding what I was trying to accomplish at the time I started it. But I'm currently up to 40m runs, because I didn't get the extra 20 from my boss, haha. So at the current state 40m. What I want is 60m due do cable paths and not getting physical structural shadows from 40m runs, LOS in other words. Even though 40m worked good last time with obstructions.
I don't think I've ever stated 60-100M in cable runs. 60M would be max. My only mention of 100m in this thread would be the specs of a cable.
« Last Edit: February 03, 2020, 04:11:57 pm by Miguel Dahl »
Page created in 0.037 seconds with 24 queries.
