Author Topic: A quick demo on frequency, amplitude and phase I did today.  (Read 1503 times)
Jay Barracato
  • Solomons, MD
Today I was setting up a demo to show the effect of changing frequency of a sinusoidal input on the amplitude and phase of the output. The expectation was that increasing the frequency should decrease the amplitude of the output and change the phase of the output.
Technically speaking, this is a sinusoidal steady state system, so with a input of vi(t) = Vi cos (wt) we would expect an output in the form vo(t) = A Vi cos (wt + phi) where A is a constant that is less than 1 and phi is the change in phase. (Not needed to understand the photos but for a LR series circuit A = R/sqrt(R^2 + w^2*L^2) and phi= arctan(-wL/R). Since the output cannot precede the input in time, the phi is chosen so the phase is lagging.
For the model, I used an input with a amplitude of 10V, a 1.0mH inductor, and a 1K resistor. The multisim model compares frequencies of 100kHz, 1MHz, and 10 MHz. For the real build, I dialed this back to a range from 50kHz to 500kHz.
The frequency effect on the amplitude and phase was clearly visible.
The real world point I was trying to convey is that any load can be modeled by a combination of its resistance, capacitance, and inductance (i.e. its impedance) and when using sinusoidal inputs we need to pay attention to both the amplitude and phase.
The first photo is the multisim model. The second is the breadboard, and the final three are the oscilloscope measurements comparing the purple input with the yellow output.
Jay Barracato
Tim Hite
    • Bad Quail
Re: A quick demo on frequency, amplitude and phase I did today.
« Reply #1 on: May 15, 2019, 11:37:28 pm »
I should probably know this already. What are the variables w and t?
Bad Quail
Sound + Light
Joshua Tree, California
Jay Barracato
  • Solomons, MD
« Reply #2 on: May 15, 2019, 11:40:59 pm »
W (usually written as Omega) is the frequency in radians or 2pi(frequency in hz) and t is time in seconds.
Sent from my Moto Z (2) using Tapatalk
Jay Barracato
Frank Koenig
« Reply #3 on: May 17, 2019, 01:32:20 am »
Try some lissajous figures as an alternative representation. Keep up the good work. --Frank
Jay Barracato
  • Solomons, MD
« Reply #4 on: May 17, 2019, 09:14:24 am »
Had to look that one up. What Frank is referring to is treating the Input and Output functions of t as parametric equations and graphing them x vs y. Since the w is the same for both functions, the graph shows the phi as a repeating pattern. Since the ratio of the amplitudes is NOT =1, the pattern is an ellipse.
Photos go from relatively low (50Khz) to high (500 kHz) in frequency.
Jay Barracato
Tim Hite
    • Bad Quail
« Reply #5 on: May 17, 2019, 12:39:56 pm »
so as y/x approaches 1 you would expect a circle with diameter = phi?
Bad Quail
Sound + Light
Jay Barracato
  • Solomons, MD
« Reply #6 on: May 17, 2019, 05:10:54 pm »
I am still trying to suss this out, but according to Wikipedia, the circle is when phi is 90 degrees. The aspect ratio of the ellipse, as phi goes from 0 to 90 degrees goes from a line, through ellipses, to a circle.
So it looks to me like the radius of the circle would be sqrt((Acos(wt))^2+(Bcos(wt+pi/2)^2)).
In other words, as a polar plot, we substituted cos(x+pi/2) for sin(x).
Jay Barracato
« Reply #7 on: May 20, 2019, 03:02:39 pm »
Don Davis discusses tuning with Lissajous figures in the first edition of Sound System Engineering.  I think that was not included in subsequent editions.
Jay Barracato
  • Solomons, MD
« Reply #8 on: May 20, 2019, 03:31:50 pm »
I can picture that, especially at the crossover frequency and the corner frequency of the filters.
I was already thinking of patching together a set of adapters to measure the filters with smaart. It would be interesting to look at them with the scope simultaneously.
Jay Barracato
Page created in 0.044 seconds with 22 queries.
