Author Topic: Portable Public address system  (Read 1334 times)
Andrew Broughton
    • Check Check One Two
Re: Portable Public address system
« Reply #10 on: May 10, 2019, 05:23:07 pm »
The Anchor stuff is pretty bulletproof (and weatherproof) and simple to deploy, though the wireless quality leaves a bit to be desired. Given your specs that shouldn't be an issue, though. Worst case you can supplement with a dedicated wireless setup. They're pretty standard issue for most school systems with outdoor extracurriculars, hell, when I was in high school we had an anchor system we used in marching band. Got plenty loud to address a hundred or so kids stretched out across a football field, so I would assume they have enough oomph to work with your use case.
Thanks, Taylor! Ever tried the Galaxy? It's quite a bit less expensive.
-Andy
Andrew Broughton
« Reply #11 on: May 10, 2019, 05:24:06 pm »
Galaxy Audio is headquartered here in Wichita and I've seen the Traveler but not auditioned it.  Based on my experience with Galaxy products, I'd expect it to do what Galaxy claims, no less and no more.
Not exactly sure what that means. Did the stuff you tried work well and sound good? How was the wireless?
« Last Edit: May 10, 2019, 05:26:26 pm by Andrew Broughton »
-Andy
Andrew Broughton
« Reply #12 on: May 10, 2019, 05:25:31 pm »
The Mipro MA708 is pretty decent.
I just had a client needing a battery operated 2 speaker system with 4 wireless mics. I tried the Galaxy TV10 first, but the noise floor of the wireless was awful so I returned it all. Then put together a setup with the MA708 that is probably 30%  more expensive but FAR better in function and apparent build quality. The handheld mics in particular are the standard issue Mipro ACT3 series with condensor capsules.
My recommendation would be to stick with no more than 2 or 3 wireless channels operating with one of these systems. We were able to get 4 handhelds working plus a wireless link between the two systems using an ACT3 bodypack, but it took some channel juggling to avoid interference. I think the fact these built-in receivers have no external antennas limits their performance.
Good info, thank you. No more than 2 wireless will be used. I'll check out that system.
-Andy
Andrew Broughton
« Reply #13 on: May 10, 2019, 05:33:17 pm »
The MA708 has a built-in CD player and Echo. It's 2019 FFS.
I mean, I hate to throw around stereotypes.... But it's not hard to tell where these are being built and sold.
-Andy
Taylor Hall
« Reply #14 on: May 10, 2019, 06:05:54 pm »
I have not, but I've seen them in a few conference room setups around town so PSAV seems to like them at the very least haha
1) Do it right
« Reply #15 on: May 10, 2019, 10:25:34 pm »
I've seen the product (actually almost all their products) but I've only used a few of them and the Traveler is not among them.  I've known the family owners for 30 years or so and know how they design, spec and contract their manufacturing.  The products are typically better than the price point indicates but don't expect anything that's not on the spec sheet or in the manual.  Again, I have zero experience with this product line.
Order a unit from a vendor with generous return policies and see what you think, Andy.
Roland Clarke
« Reply #16 on: May 12, 2019, 05:11:14 am »
That doesn't necessarily have to be the case. If the wireless mics are part of the system, they can be internally eq'd and gained appropriately and "just work".
Let's not go into a discussion about how small committees should be hiring technicians or whether not-for-profits need to have an A/V person on staff, just looking for opinions on the best system that's user-friendly, will last and sounds good.
Hi Andrew, I wasnít suggesting for one moment about hiring pro techs, itís obvious from your first post, this isnít what you/they are after.  Iíve seen systems in churches that are almost plug and play, but the gain structuring is set up and locked off and they are left with a couple of knobs or faders to control, Soundweb, etc make this stuff, but out of your budget and remit.
My suggestion would be to buy a small Yamaha style system and a simple analogue mixer and add a couple of bits of tape with gain position marked off on it.  Wireless, well thatís as complicated or simple as you buy, not sure of anyone integrating it.  LD systems do some decent but cheap gear.  Whatever you do, I think you are going to have to set up a training day and possibly print out a step by step manual so it can be user operated or volunteer operated.
George Friedman-Jimenez
  • NYC
« Reply #17 on: May 12, 2019, 10:53:39 am »
Has anyone tried the Bose S1 Pro? It is very small, light, can run on batteries, has pole mounts, Bluetooth, wireless mic receiver, 3 ch mixer with line out, +/-3 dB at 62-17k Hz. Downside, the claimed max SPL is only 103 dB at 1m. I haven't heard it but saw a good review in Sound on Sound. Not sure if it would be loud enough for OP's needs, although you could daisy chain 2 or 3.
Steven Cohen
« Reply #18 on: May 12, 2019, 12:05:33 pm »
Andy,
We have about 5 Anchor Audio AN1000x in our inventory. We give them to non-technical people to use at meetings. I configure the systems as robust as possible by including an SM-58, a Whirlwind MK25' mic cord, all contained in the Anchor Audio CC100 case. The system is lightweight, easy to use, provides undistorted vocals with coverage for 50 seat meeting rooms. We generally get about 10 years of daily use out of them before they need to be replaced.
I have not used their wireless options for the AN1000x or know how they hold up with outside use.
Steve
What's decent quality in a small portable system that can do the following:
1-2 Speakers on stands with integrated wireless, 2 hand held W/L mics, 1 iPod/Phone input for music (BT would be a bonus)
Something that packs together but has decent quality as well as able to withstand a bit of rain and keep working. Bonus if it's lightweight and easy to carry around.
For a community center for meetings and outdoor announcements (<50 people), so operated by non-technical folks. Something that sounds good out of the box.
What's decent these days?
« Last Edit: May 12, 2019, 12:16:43 pm by Steven Cohen »
¬ę Reply #18 on: May 12, 2019, 12:05:33 pm ¬Ľ
Page created in 0.764 seconds with 22 queries.
