Author Topic: Ethercon to Ethernet Adapter?  (Read 7388 times)
David Pedd
  • Gilbert, AZ
« on: May 06, 2019, 06:37:34 pm »
Hi.
I'm wanting to purchase a flexible, CAT6 cable with Ethercon connectors (usually those cables are the most protected) for when I'm on a job site and need to lay a cable for a camera connection or whatever.
So my equipment doesn't use Ethercon connectors and I'm looking to find an adapter to convert the ends to standard RJ45's.
Any suggestions?
Thanks.
David Pedd
  • Gilbert, AZ
Re: Ethercon to Ethernet Adapter?
« Reply #1 on: May 06, 2019, 07:22:19 pm »
I think I've found the answer.  This item:  Neutrik NE8FF Ethercon Connector Coupler
Jean-Pierre Coetzee
  • Gauteng, South Africa
« Reply #2 on: May 07, 2019, 04:50:19 am »
Unless there are molded models of the ethercons that I don't know about wouldn't it be easier to just remove the ethercon connector? Also I seem to remember that the CAT5e and CAT6 ethercons are not compatible with each other or something weird like that. Keep that in mind.
Audio Technician
Word & Life Church
- Ivan Beaver
Samuel Sjöbergsson
« Reply #3 on: May 07, 2019, 08:17:51 am »
Yeah don't get cat6 Ethercon cause it's not compatible with cat5 or cat 6A, 6E or 7 but all other Ethercon is compatible with eachother.
Taylor Hall
« Reply #4 on: May 07, 2019, 08:25:13 am »
Depends on the flavor of ethercon end. Some brands are not user serviceable and are effectively molded together like you say (And in many cases without any shield bonding despite being listed as cat6!). Also, many ethercon connectors require you to snap the locking tab off the RJ45 end, so simply removing the ethercon shell would result in a very unreliable connection at one end. Neutrik also notes that some of their connectors are not compatible with cat6 panel connectors, so I'm not sure if it's some physical aspect of the connectors themselves or the difference in cat5/6 protocols and other ethernet standards (PoE, etc).
It's also worth nothing that a lot of the d-series panel connectors have standard RJ45 outlets on the back side, so if your non-ethercon equipment usually lives in or near a rackable space you could just mount one to a punchout plate and run a standard ethernet cable from there.
1) Do it right
Pete Erskine
    • Best Audio
« Reply #5 on: May 07, 2019, 08:27:44 am »
Then I'm on a job site and need to lay a cable for a camera connection or whatever.
Any suggestions?
Thanks.
Buy your ethercon from GLS.  the connector easily changes to regular rj45 and back
GLS-Audio-G-Shell
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #6 on: May 07, 2019, 09:42:50 am »
GLS-Audio-G-Shell
That's slick.  Now just need to find a way to lanyard that shell to the cable so i don't lose one on Every Single Show....
brian maddox
bdmaudio@gmail.com
Cailen Waddell
« Reply #7 on: May 07, 2019, 10:17:48 pm »
GLS-Audio-G-Shell
Just FYI the cables I’ve seen with these connectors, the shield on the Ethernet cable is not grounded to the shell.  Can be a problem for certain Midas and Behringer products.
Mark Cadwallader
  • Helena, Montana USA
« Reply #8 on: May 07, 2019, 10:57:32 pm »
Or to get Neutrik to make an EtherCon version of the Neutrik NC3FM-C-B ConvertCon, so the shell just slides back out of the way as needed.
Kevin McDonough
« Reply #9 on: May 08, 2019, 04:23:53 am »
Yeah, as you've said by far the simplest way is just to use the ethercon joiner barrel, and on the outgoing side use a small 1m or 2m normal ethernet cable. We do this all the time and works fine.
k
Page created in 0.063 seconds with 23 queries.
