Author Topic: crown amp question  (Read 3658 times)
Jody Gould
crown amp question
« on: May 05, 2019, 06:35:18 PM »
i want to use my crown microtech 1200 in bridge mode to power a meyer 650 r2 which is biamp. (4 pole speakon) connector.   my cable im thinking about getting would have two banana plugs on one end and the male speakon 4 pole on the other end.
question.    On the crown amp you plug the first banana plug in for bridge .  do i stack the other banana plug on top of the other one??
Re: crown amp question
« Reply #1 on: May 05, 2019, 08:24:57 PM »
You can't use a bridged amplifier for a bi-amped speaker.  I think you do not understand what "bi-amped" means.
Jody Gould
« Reply #2 on: May 05, 2019, 08:41:00 PM »
can you tell why you cant?  i would have power going to 1plus and 1neg and 2 plus and 2 neg. Wouldn't  the bridge amp would send out 970 watt at 8 ohms to each speaker
  • Old enough to know better
  • Audio Plumber
« Reply #3 on: May 05, 2019, 09:17:03 PM »
The term "biamp" usually refers to a speaker where different pass bands are driven by different amplifiers, like low on one amp, highs on another, with an electronic crossover or processor ahead of the amp to divide and control the signal.
Your 650 R2 subs have only 1 pass band, sub lows. If they are wired to both channels of the NL4 or EP4 you would wire the 2 circuits in parallel, 1+ and 2+ on the plus terminal of the amp, and 1- and 2- on the minus terminal. You could do this by stacking banana plugs. Since your Crown Macro Tech 1200 is rated at 495W into 4Ω, and the 650 R2 is rated for an amp of 400W into 4Ω there is no reason to bridge the amp. Use 1 amp, with 1 speaker per channel. The amp specs do not mention using them briged into 4Ω.
« Last Edit: May 05, 2019, 09:25:11 PM by Mac Kerr »
Ray Aberle
    • Kelcema Audio
« Reply #4 on: May 05, 2019, 09:22:37 PM »
Well, if you would like to learn from "Ye Olde School of Hard Knocks," hook it up and see what happens.
[pedantic: the cable has a *female* connector on it, not a *male* connector.]
[Mac's explaining things better so I'm gonna leave it alone. heh.]
Kelcema Audio
Jody Gould
« Reply #5 on: May 05, 2019, 09:33:05 PM »
reason i was trying to bridge it, is because, i was trying to use the meyer processor for two subs.  using a y cable out of the output. one to one 650 one to the other 650.   sounds like i can only use i meyer processor per sub now. because out the y cable to stereo input of the crown.  then each side out to a 650.   is that right? thanks
« Last Edit: May 05, 2019, 10:04:03 PM by Mac Kerr »
  • Audio Plumber
« Reply #6 on: May 05, 2019, 10:08:15 PM »
No. You only need 1 B1 processor for all the 650 subs you can gather. It is still a single channel of signal going to many speakers. If all the amplification is the same, including the same gain, a single channel of processing and its included sense input is all you need.
Jody Gould
« Reply #7 on: May 05, 2019, 10:19:43 PM »
well that good.  would you mind telling me the signal flow. and what cables to use.   so far i know that from my crossover out mono to b2 processor,  then y cable out to the amps. this is where its confusing.  because if i just go into the right side of the crown microtech 1200 then it just comes out right side of amp.  thats why i thought to use bridge, stacking the banana plugs
  • Audio Plumber
« Reply #8 on: May 05, 2019, 10:58:43 PM »
Seriously. Read a book. Setting up sound systems is not difficult, but neither is ti easy. You need to get a broader sense of what you are doing before you ask other people to help you. You seem to be stumbling around in the woods without a clue and asking the members of these forums to hold your hand through every little step.
Since I expect you want to know where to get such a book, try HERE
« Reply #9 on: May 05, 2019, 11:11:23 PM »
Even after talking to you and making drawing you are still struggling with this.  The processor is on the input, it has nothing to do with being bridged.  You can run as many amps as you like off the processor.
When you bridge an amp you combine the output of the two channels (you only feed one input when bridging) into a single output (the + of each side, see manual as doing this wrong can damage amp).
As per our previous discussion, bridging with this amp is not a solution since you would have a 4 ohm load with the two MS-18 (8 ohm) drivers that are in the 650R2 in parallel.  The amp is really too small, you won't have any headroom if you run one cabinet in 4 ohm mode (drivers in parallel) per channel or run one channel to each driver in the cabinet (one amp per cabinet).
You also need to make sure you understand the sense circuit and properly gain staging the processors.  The sensitivity switch is on bottom of the PIP card slot on the amp, you have to take it out to get to it.
Have you read the Meyer manuals and the Crown manual?
You know Jody some folks just aren't technically minded.  You may be an ideal candidate for powered subs where all this is taken care of for you.   The Meyer 650P is same sub powered.  If you have the original MS-18 drivers in your cabinet, not MS-18 frames reconed with EV kits as many on the market are, you could sell your 650R2's and amps and have powered subs to match the MSL-4's.  I think that would make your life a lot easier.
Page created in 0.064 seconds with 25 queries.
