Author Topic: My wireless DMX findings  (Read 810 times)
David Allred
« on: April 20, 2019, 03:36:28 pm »
 While checking on the PCB style trans-ceiver units for a project, I decided to play with my dongles.
I have 2 Chinese dongle transmitters and 8 or so receiver dongles (button style).
This what I found.
The transmitters (with antenna) also receive.
The button style receivers will not transmit.
A fixture can receive dmx signal from Male or female side as long as a physical connection can be made, with a turn around (for example).
If a fixture has an input from a wireless source, a transmitter can't be used as a repeater on the output to other fixtures on the same wireless channel (color).
But, one can repeat if on a different channel (color).
Maybe that will help someone.
Lyle Williams
Re: My wireless DMX findings
« Reply #1 on: April 21, 2019, 10:54:34 am »
What are the button-style receivers?
David Allred
« Reply #2 on: April 21, 2019, 02:37:57 pm »
The kind without antennas.  (Round ends that light up.  Rounded like a button.)
Steve Garris
« Reply #3 on: April 21, 2019, 03:45:36 pm »
This is informative - didn't know!
I assume you are talking about these:
https://www.donnerdeal.com/products/bundel-donner-2-4g-dmx512-wireless-transmitter-receiver-built-battery?variant=8786569953369&utm_medium=cpc&utm_source=google&utm_campaign=Google%20Shopping&gclid=EAIaIQobChMI_72VzPjh4QIVXx-tBh3jHQdlEAQYAyABEgJedPD_BwE
David Allred
« Reply #4 on: April 21, 2019, 09:05:08 pm »
Lyle Williams
« Reply #5 on: April 22, 2019, 12:33:37 am »
The least fun thing about the transceivers is the ability of something you considered to be a receiver to become a transmitter.  Someone cycling through the fixtures settings can trigger this.
Jason Fultz
« Reply #6 on: April 22, 2019, 09:30:51 am »
Correct.
The pcb types are either.  If they detect dmx they automatically transmit.  If they don't, they scan for a wireless signal.
So let me make sure I understand. The pub add on style  Transceivers are a transceiver, the both recieve and transmit dmx at the same time.
So adding these to some of my fixtures would create a wireless network of their own also.
I've been using the Lixada light up button type for a while now pretty successfully and like them.
But being able to add some of these to permanent installs would be cool.
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #7 on: April 22, 2019, 07:59:06 pm »
No. They are either but not at same time.
David Allred
« Reply #8 on: April 23, 2019, 03:53:45 pm »
Rob is correct.  But you could set up a "red channel" as level 1.  Red transmit to red receive on a fixture (or fixture) within range.  That same fixture, with a "Green" transmitter on the output, could transmit to a slew of Green receivers that were out of range of the red transmitter.  rinse and repeat.
Lyle Williams
« Reply #9 on: April 24, 2019, 05:30:17 pm »
I am not sure that the output is properly differential RS485.  I suspect that they only apply signal to one pin.
Page created in 0.061 seconds with 20 queries.
