Author Topic: Question about horn design  (Read 2892 times)
duane massey
« on: March 17, 2019, 01:49:29 pm »
In the design of a front-loaded horn (full-size, not vented or tapped horn) what part(s) of the design would be affected by the parameters of the chosen woofer?
Duane Massey
Houston, Texas
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
Re: Question about horn design
« Reply #1 on: March 17, 2019, 04:31:19 pm »
It's important to note that very few bass horns are "full-size". Most end up with compromised mouth size, and rely on multiples working together to increase the mouth area enough to support a flat LF response.
With regards to your question, I'd say the answer is everything. You can't design a horn without a driver, and similarly you can't pick a random driver to go in a horn - you need to find something suitable for the task at hand.
Chris
www.grimshawaudio.com
« Reply #2 on: March 17, 2019, 08:11:44 pm »
The answer has a lot to do with "What do you want the horn to do?"  and more.  Are you looking for simply gain-over a limited freq range.  Or do you want extension?
The cabinet and driver are selected to work together.
Everything is a compromise, and you are constantly trading one thing for another.
Depending on certain things, a "wimper" woofer could produce better results.
duane massey
« Reply #3 on: March 18, 2019, 02:12:20 am »
When we built this massive pair of 20hz horns in the 70's the designer didn't have a particular driver in mind, other than the size. The results were phenomenal, but I was not aware of the details behind his design. Built a few smaller ones in later years, based on his notes about the flare rate and the compression volume, but never really thought about the woofer itself.
How would the driver affect the flare rate? The volume of the compression unit? This is all just out of curiosity on my part, as I will undoubtedly never have the opportunity to build any more of these.
Duane Massey
Houston, Texas
duane massey
« Reply #4 on: March 18, 2019, 02:27:52 am »
Pic of one of the horns
Duane Massey
Houston, Texas
John L Nobile
« Reply #5 on: March 18, 2019, 10:19:36 am »
Jeff Bankston
« Reply #6 on: March 22, 2019, 01:53:09 am »
Michael Thompson
    • Factor Audio
« Reply #7 on: March 22, 2019, 02:27:48 am »
You will probably find more in depth answers to topics like this at diyaudio.com.
Dave Garoutte
  • San Rafael, CA
« Reply #8 on: March 22, 2019, 12:44:47 pm »
Inventor.
Keith Broughton
  • Toronto
« Reply #9 on: March 23, 2019, 07:06:09 am »
Hornografic images.
Good one ;D
From my limited understanding of straight horn design, I would think that in low frequency applications, it's the back loading of the driver that has more impact on what driver parameters are required.
